correct on the compression, but you will have much larger ports and valves. I will take the flow every time....The theory is that if I shave the 360 heads they'll be close to the compression the 318 heads currently have with bigger valves ?
Yah i know, just trying to get a dye grinder into you hands.
Have you deside what cam you will be putting in the teen?
Old axiom of hot rodding: ..." Make what you have, work...."By the calculations it looks like a .450 or so lift which should be good I guess since everything is running fine. questions questions questions definitely would like to invest some time in trying to make the 360 heads work but will the springs from the 318 and retainers work to the 360 head? Ones in the 360 don't look as going. If I bring the Pistons to the top clean them real well and then flush out with what like WD-40 or something? so nothing gets near the rings? how far could I shave the heads? And maybe shave the intake manifold which is one of the only Parts I don't have. That will let me have something to look for at the big swap meet here in a couple weeks. I did dig out the 600 Edelbrock that I bought for $10 from a friend last year and I've been robbing parts off for my to Edelbrock on the Stroker so I'll have to buy some little pins and clips to replace what I've been robbing. It doesn't look like I'm going to get the opportunity to use my 273 rockers but that's fine? View attachment 1715031922View attachment 1715031923
Aren't the piston setting in the hole quite a bit, Valve to piston shouldn't be a problem. and was told vavle to syl wall was only a problem with 273s.
My math i did to day say the .040=8 cc and my X heads showed that a .080 you have made an open chamber head a closed chamber head. Head chamber bore is around 4.00"
Well the biggest question I'll be trying to answer this week will be how far I can mill the heads and if the 360 heads, I mean if the valves are good. At what point should I start worrying about valve 2 piston clearance with the bigger valves?
I have heard of people going .100 mill on the heads...............carefully pour solvent down the ports, if nothing leaks out into the chamber, seats/guides are good.......think about it........if the guides are bad, the valve is not gonna hit the same spot twice in a row on the seat...... it will leak........Use Stoddard(sp?) solvent as it has no surface tension
If in doubt, just clay the piston/valve for clearance, that way you WILL KNOW, NO GUESSWORK, move along..........
Coffee !
View attachment 1715031943 View attachment 1715031944 the second bearing from the rear end has a chunk of something embedded in it. Thats the worst part of that and no oiling gruve, but in general good shape. Almost don't want to clean the Pistons gaining point or two in compression with that much carbon LOL.
I had cam bearings that looked very similar. The machine shop said it's very common on the Babbitt bearings I was using. They tend to flake off. Anywho I'd run em.
Mostly because the title is $50 Craigslist build.
- Ok, you mentioned you don't want the "heard of a guy" stories on what might work. This I have actually done myself, more than once..... and my experience has been that I've cut 360 heads .040 and have never cut the intake. Do you realize if you use the felpro head gaskets in the kit we discussed, your are adding about .025 in thickness from the factory??? So, your really only gaining about .015 even though you cut them .040, Savvy Mate?
- Clean up each valve and inspect them. Problem is, the exhaust take a beating. A lot of times I find it necessary to buy new exhaust valves. On the cheap 50 bucks for all 8. Intakes usually lap out nice. Pour rubbing alcohol in the ports, one at a time, and see if any leaks past the valves. If it does, then it's not sealed. Also, shine a flashlight into each port with the lights off, and see if you can see a sliver of light coming through the valves. No matter the rest of the build, if those valves don't seat, the engine will perform like a GM bent-valve 305.
See here you are telling me that people are giving me good information and I'm not listening or drinking the Kool-Aid LOL and your first comment is I heard of people doing something? I've heard of people trying to take a poop while running uphill. I mean really I'm supposed to go out and mill my heads because you heard somebody did it before Should work I mean when you think about that that's why I don't drink everybody's Kool-Aid. Then you go on to tell me to think about it? I don't think about stuff? again the condescending comment implying I'm stupid. Are you proof reading this are you trying to put me down ?
So I assume you're implying I might try cleaning everything up putting the cam back and setting the head back down and pre clay testing what I have so I know how much I can mill the heads down is what I would have thought of if I was a thinker. that's probably the advice I would give somebody. I've alluded to it before but now I'm going to flat out say it I very much appreciate your help but I can certainly do without the condescending comments that have to come along with it thank you very much again for your help and especially your experience not what you heard somebody had done.
This was the first port that i did with my home made flow bench and i found out latter that i had not calibrated it correctly! but this was the only port that i did a single cut and tested it. all the rest of my ports i cut the 2.02 in got the deep bowl cut in and then started testing.
