Started converting an old blower to gas for a 400 I have. Naturally, the manifold is 2x the price of an RB one. I have already procured an aluminum 2x4 offy for the donor. But that will be later. I got the case stripped down and cleaned. Looks pretty smooth. There is a little staining, but in otherwise it appears to be in great shape. The rotors also, although filthy, have nice edges and no gouging. Made sure to label what used to be the top and bottom rotors. I cut the top lip off and started forming the edge to match the other side. It says Anderson Delco Remy. Can’t find anything on that specifically. I also removed the cross braces on the top and bottom. Should be a fun project. I don’t care to buy one already built. I still need to source some new gears. I’ve only been able to track them down via one company. If the GM part I use sticks out of the hood, it’s technically not “in” my mopar
