/6 overheating need help.
OK, Just so I've got the chain of events down:
When you bought the car you installed new radiator? or was the radiator in there already?
You installed an electric fan shortly there after and all was good for a while.
Fast forward 2 years.... You fixed the A/C and now it overheats? is that correct?
Pretty good posts here. Sorry my user name caused some confusion... it's player1up...like in old arcade games :lol: I see that I shouldn't take a couple days off the forums.
I don't care what people say about RustyRatRod, he's OK <-- teasing :)
Not having a fan shroud could cause the problem at idle, but at speed it should have air flowing through the entire surface of the radiator.
One issue that I've heard of ( never experienced myself ) is that a fan can actually create an air dam effect if it's running while the car is at speed. I will say that the electric fan in my 360 never runs while I'm moving more than about 25 mph, even at a 101° heat index here in FL
I will agree that adding the heat of the condenser core will put more stress on the cooling system, but if you run without the A/C on the core shouldn't cause enough of a restriction to overwhelm the system.
At this point I'd start over and double check everything....sorry.
This is why I think "check everything":
A lower temp thermostat can sometimes cause problems if it stays so hot that it never closes.
It will act like there isn't a thermostat in there and the car will heat up indefinitely because the coolant doesn't stay in the radiator long enough to cool down. -- personal experience ( when I was a bit younger )
This makes a little sense because at idle the water pump is moving much slower and allow the water to stay in the radiator long enough to cool down. -- research
A radiator that is "oversized" for the application can mask thermostat problems because it will let the coolant temp drop enough. -- research
A radiator that's just barely enough ( or has flow problems ) can be overheated with minimal additional heat.
Smokedya, Did you do a flow test on the radiator yet?
Some of the info posted here is from personal experience and some from research done while I was having the issue with my car and I've tried to point that out where needed.
I know it's a huge rambling post but what I'm really getting at is:
1. Testing / verification is your friend ( time consuming but worth it )
2. Document findings / behavior
3. Cross reference with known matching symptoms.
Yeah I did a pressure test on the cap and the whole system its self out all checked out. I did a flush of the system and the water came out rusty as hell so then I installed a 195 thermostat and now it doesn't over heat at all. When I pulled the radiator to get the compressor out the water came out clan I think it was blocked somewhere and water flow sucked. Now its strong and the car runs at 200 with the a/c on. Ive been really busy lately and didn't have a chance to reply to everyone.
And I had the car for at least 8 years now the old radiator just couldn't cool it anymore I tried everything then changed it.
