PocketAces
I took the new pistons out to L&R engines so they could hone the cylinders to the final bore. They do that with a torque plate to simulate the strain caused by the cylinder heads torqued down.
The next day, I went back out to cc the dome volume of the pistons. I put a piston in a bore and adjusted it so that it was 1/2" down, measured from the lowest part of the top of the piston. I smeared a tiny bit of wheel bearing grease around the perimeter to prevent the liquid from leaking out between the piston and cylinder wall. Then I cc'd the volume above the piston, which measured 74.5 cc's.
A cylinder with a diameter of 3.655" and a height of .5" should have a volume of 5.25 cubic inches or 85.97 cc's.
The difference, 11.47 cc's is the dome volume of the Kanter pistons. Given the accuracy of the process, I'd say the dome volume is approximately 11.5 cc's.
Since that's bigger than I was estimating, I told L&R to take a minimum cut to square up the block. That should be about .005" leaving a deck height of 9.605"
Once the engine is assembled, we'll measure exactly where the pistons set relative to the deck, and then decide how much to mill the heads.
