Capt46
Hi all,
Question to the wizards was checking out the tach today removed the tuna fish can and when I had removed the can from the body key on the tachometer pinned. I then grounded again and it returned to the start position '0' again removed the ground and it pegged out. I grounded again it returned the the start position. I then started the car and nothing. Based on these symptoms does anyone have a clue? Thank you Capt46
