76orangewagon
First off, Happy Veterans Day to all of my fellow brothers in arms defending our great country...I salute you all. Now Every time I walk around looking for things to make a little cleaner before paint I find more and more small modifications I just cant let slide by....This week, I decided to fill the rear shock bolt holes and cut outs, then when I mocked up a front shock with the proper 1.5" washer to fit in the huge factory 2.375" hole, so that got tightened up to 1.625" then decided to look at the firewall heater hose holes, the brass heater outlet/inlets are .750" and the holes are 1.00" plus so they are now .875". Then once I realized I never welded the factory quarter panel to trunk pan supports back in, the wheels in my head started turning again....1st, I thought just make new steel ones, then make custom ones with a cool name in them..but what if someday the name gets old..then make them removable and then I can make them say whatever I want, whenever I want...then decided to go .160" Aluminum and oversized from 2." to 3." at the base and then they'll match the fuel cell appearance, So........Now I have a changeable oversized Aluminum support that is totally customizable later on.....finally made some Heavy duty rear tie downs for the frame...and its scheduled go to the body guy within a week or so....I need a Rum..anyone want to come join me ?
