Dude. . . you have a Scion????
Ordering a Cage from autoweldchassis.com , 12pt Chromoly. A Pillars are bent to go through the dash. I can not buy the material for how much this one costs already bent. I will probably install the 8pt portion and then add the halo and forward portion at a later date.
$370.95 12 Pt Cage
$265.00 Chromoly upgrade
$39.95 Rear bars to follow Roof Line into trunk & Clear Rear Seat
$20.00 if you want it all pre notched.
http://autoweldchassis.com
Adding weight is only going to slow you down. :-D
On a serious note has your buddy started on the 67?
Ordered a new driveshaft it was just too damn short. I needed one 2" Longer. Ordered a 3.5" .083 Wall with solid 7260 U joints…… $225.00 Also bought a new Transmission Pinion Yoke $66.00
I will keep the other solids I just bought as spare's on the bench.
So that number worked out well?
If so, cool he'll put a 7260 ends in it for you.
I was reading your thread last summer but haven't been on here much this fall/winter. All caught up, looking real good! I'm going to tackle a 904 myself soon, it's going behind a 340 in '71 sweptline ratrod lowrider project I'm working on with my kid. I've watched those YouTube videos on the 727 rebuild, plus I have a couple books. Besides the sprag not bolting in, any other notable differences? I have a reverse manual valve body going in just to keep my shifting pattern the same as the Demon. Good luck with the rest of your mods!
Well I am keeping the column shift & bench seat in the car for now.
Something trips my trigger about a Column Shifted, Bench Seat Sleeper that is capable of running in the 9's. Gunna try to get it there!
Cage should ship out next week.
Got lots to do!
wow, you were able to talk to Joe at Tranzact? Thats a miracle...I tried contacting the guy god knows how many times after ordering my valve body for a span of a few months...left messages, sent emails, all for getting more parts....NOTHING
