Mad Dart
Nothing to see Here!
The work looks killer! I've got a little 66 Dart waiting for some ladder bar/coil over treatment. Do you happen to have any pictures of the ladder bar cross member? Did you use heims on the front and solid rod ends on the rears? Thanks!
It is this one
https://www.cachassisworks.com/p-15...spension-with-1-58-crossmember-no-shocks.aspx
Solid everything! The Hiems are pretty big and beefy. Probably the beefiest out there.
You still need shocks & brackets & shock cross member to make a full kit. With shocks etc I got about $1250.00 into the Ladder Bar set up.
Here is the complete kit....... I decided against it because I wanted to use Strange Shocks and QA1 springs. Plus I used different brackets and cut them up different on the housing so my shocks did not go into the trunk. If I wanted the car to sit REAL high in the back then their kit brackets would work.
https://www.cachassisworks.com/p-15...on-with-1-58-crossmember-with-coil-overs.aspx
