superchargeddrt
Oh by the way, it has an electronic gauge.No leaks now, the Superformance rear main seal seems to be doing it's job.
I didn't have this high of pressure before I replaced the main seal and remote filter adapter o-ring. It used to be 30 at idle and 70 at 5800 RPM. At the moment I don't see any leaks but before it leaked like the Exxon Valdese. Oil made it's way all the way back to the the trunk panel .The Superformance rear main seal seems like the real deal
That's what I was thinking. Not so much the main seal but the o-ring for the remote oil filter relocation kig that seals to the 90° oil adapter. I will keep an eye on things but right now NO OIL LEAKS!!!! Woooo HoooOk, lets look at this another way. You're talking about a 20 PSI increase in both the low RPM and high RPM oil pressure. That's not very much. The leak you describe could certainly have been the pressure loss. Does that bring it more into perspective? 20 PSI.
Mbaird,the rear main on my fresh 360 in my Barracuda is gushing...urghh... it was hard to tell one side from the other on install. I should have just ordered a good one instead of risking it... urgh....
Thanks for the input... I dont run a windage tray so it should be a fairly straight forward replacement. I never thought about clocking the main seal abit... makes sense. Why doesnt anyone make a 1 peice seal for a mopar ?
I am just hoping it doesnt turn out to be a leaky cam plug or loose oil galley plug !
Probably not... no pressure anywhere directly on the rear seal; just part of what flows out of the rear bearing and does not get slung off. Seal leakage is an 'engine running' thing.
I was thinking the same thing on mine but if I were betting I would think it's going to be the main seal with the way you are describing it as gushing.k
I was refering to the oil galley plugs and maybe cam plug leaking if I prime system.
Roger...k
