Hello doing restomod on My 1966 Dart GT. Is original radio delete GT. 4BBl 273 rebuilt and still in there. Having real issue with with fuel pressure. any one using a intank pump? Stock tank, no fuel cell. If so what pump works out.
That system that Beatnik shows is for Fuel injection. PSI too high.
Here is your best bet, We use these tanks all the time in my shop. We are also a dealer for them. So could save you a little cash. They are a direct bolt in to your old tank an have several pump options for what ever H.P your running.
http://www.tanksinc.com/index.cfm/p...ct_id=397/category_id=68/mode=prod/prd397.htm
I got a Tanks Inc. kit for my '69 Dart. But it was not really bolt-in. I had to buy a new tank and have Tanks Inc. weld the recess into it for the top of the pump module to fit down into. Otherwise it sticks up about 1" above the top of the tank and the tank cannot be installed in the car. (Well, you could cut a hole in the trunk floor I guess, but who wants that?). Anyways, it works great. They have several pumps to choose from, I'm running a PA-Series full return system with the TBI pump which puts out 12psi. Using an Aeromotive 13351 bypass regulator set to about 6.5 psi at the carburetor.
The recess:[/QUOTE interesting we use them all the time. Have never had an issue like that. If the sending unit sits on to of the tank like you posted they are all ready recessed.
The recess:[/QUOTE
On a '69 Dart the sending unit is on the front vertical wall of the tank. The Tanks Inc pump would never fit there, plus it won't work sideways!
It boggles my mind that ANYONE would want to put an electric motor IN a gas tank....its more quiet, but thats about it. I know its been done about 30 million times since EFI was mainstream...
