A QUICK QUESTION ABOUT MANIFOLD VACUUM
CFD244
"THE NEW OLDSMOBILES ARE IN EARLY THIS YEAR"
Northern Ontario, Canada
Hi Folks
The facts..........
Fresh 340 (with about 2hrs run stand time) with 9.3 CR, running a Comp XE262 cam. OEM intake with a 1972 TQ.
Base timing 20* btdc (MP gold shaft distributor.) Engine installed on a run stand, all warmed up..............
Smooth idle at 850 rpm pulling just under 15 inches on the vacuum gauge. Needle dead solid with 20* on the timing light. A/F 12.8
Run it up to 1700 rpm and I see an erratic vacuum needle in the 18-21 inch range. Timing light shows a solid 34* with the extra 14* coming from the ported vacuum signal.......Disconnect the can, back to 20*. A/F 14.2
So my question, does the erratic vacuum signal at 1700 rpm sound normal?
Thanks FABO
EDIT: Vacuum signal measured at the rear port on the carb. base (not the dashpot fitting)
Not really. With a some extra overlap its usually least stable at idle rpm. But 3" Hg not sure I'd worry about it unless something else is going on.
Now why the advance isn't coming in before 1700 -rpm that would have me asking questions.
I double checked my numbers........That distributor actually comes in at 1500 RPM and puts 14* in by 2000 RPM. There must be a slight variation in tachometers. At any rate, the erratic needle occurs in the fast idle zone (with choke open obviously).
My guess is that the VA unit is not deploying fully [ ie. the plunger is not pulling all the way in { see-sawing } ] such that the amount of vacuum is varying slightly. If the VA unit is adjustable, turn the screw fully CW.
Depends on the quality of the vacuum gauge. Cheap parts store vacuum gauges made in the last 15 years? Yeah, it's pretty normal. High end diagnostic and high end liquid filled vacuum gauges? Yeah, if those are erratic, you may have an issue. Otherwise, I'd say it's normal.
While the rpm is up , and the vacuum is dancing, watch the timing marks. If they're dancing to the same drummer, put an independent vacuum source on the VA and repeat. If the dancing continues, check for timing chain stretch.
But if the dancing stops, blame it on the VA. To prove it, disconnect the VA, then run it back up to 1700 and simultaneously advance the timing to 34*. If the dancing is back, it wasn't the VA.
So then, Ima thinking your combo may not like 34* @1700 rpm.
So then, still at 1700rpm, and running 34* mechanical timing; just reach in there and retard the timing until it stops dancing, keeping the rpm at 1700. Then read the timing at 1700.
But if nothing seems to work, check your rotor phasing and plug gaps.
I have seen the VA pull the plate over, and the mechanical advance align in weird ways that causes the rotor to be marginally positioned and the sparks go to the wrong tower. And I have seen coils misfire, in weird ways when the plug gaps combine with lean AFRs , and the coil just says, OOps no can do.
And a common mistake is to run the Numbers 5 and 7 wires too close to eachother, causing induction crossfires, and then the engine gets two fires on those two plugs but 90 degrees apart. Not good if one of them is on the intake stroke.
Good luck
Good luck
Timing mark is rock solid no mater where it is, or what I do (in it's respective location relative to the RPM and/or vacuum)
Well that rules out chain stretch, flyweight/spring chatter, and VA flutter.
With that 262 cam, the intake vacuum should be rock-solid by 1800>2000rpm. The cam has settled down, and all the intake air should be going in the same direction. The manifold vacuum, should have increased steadily from idle, and peaked in that pocket, and it should NOT be fluttering around 1700.
If the timing is solid, then it has to be; a bad plug, rotor phasing, induction X-fire, the feint beginning of pre-ignition; or maybe, AFR but that, I doubt.
To help in diagnosis, I would check the spark-strobe of every wire, beginning with numbers 5 and 7. You'll be looking for missed strobes, multiple strobes, or out-of-time strobes, at 1700 of course..
Hi Folks
The facts..........
Thanks FABO
Upon returning to idle from a rev up in full advance it's lean. Or a miss.
It's 12.8 at idle, then it's 14.2.. right?
Should be 13 something or so at idle and richer at throttle. Unless I'm reading this post wrong.
Is this a dial back timing light?
No dial back timing light. I can lean out the mixture with the a/f screws to get into the 13's.
I just found it strange that the mv is perfectly stable at idle, and gets a little erratic in the fast idle zone. I might try the vac gauge on the manifold fitting instead of the car base and see if that makes a difference.
I was just concerned that it may be a vacuum leak........I tried a propane torch around the carb base and intake with no change in rpm.
I'm with the others ... in that it's on the edge of mech advancement during the vac instability
Timing tape?
It's spinning at 1700 with no load, a lot of timing and somewhat lean mix. Maybe if you had a load on it it would be slightly trailer hitching or even reving and dying. Run an engine too lean at light to moderate load and you'll know what I'm trying to describe.
I agree. Idealy. But a little richer will seem smoother as long as the plugs aren't fouling.
It seems like more timing than needed for the AFR and rpm given the cam and the vacuum reading.
Here's two data logs off my 340 showing rpm vs. AFR when opening the throttles very slowly.
One is in neutral and the other driving the car.
... a couple logs showing slowly increasing rpm with small throttle opening.
The AFR gets leaner with increasing rpm, but only when there is load.
I was wondering if the vac source location plays a role in it?
Since its on the stand, there's only so much you can do. But don't worry about the AFR number. Its just a number, even assuming the exhaust is long enough and the idle conditions are good enough the WBO2 is getting interpretted correctly. A CO meter is better at idle, but again its not important.
For a given timing and throttle position, turn the idle mix screws in until the rpm starts to drop off (or vac drops off), then back out to the point it was before it dropped off. Then I'd make it another 1/16 or 1/8 richer. Now go take a reading and note it down just so you have a record to refer to.
Thanks for everyone's input. :thumbsup: I will revisit this issue with your suggestions when I fire it up next time.
Just plying around...........
Found that the engines happy place idling is 25* BTDC. Unfortunately, I found that it bucks the starter a bit when it's warm. I fashioned a "stop" for the vac can and adjusted the VA spring with the least amount of tension (comes in at 9 and stops at 14 vac).
I am now running manifold vac limited at 15* and 10* base for my 25* idling. Manifold vac is now 17 and steady at idle, and steady (new gauge) at 21 at 1700.
I have 3.23's and a 2600 -2800 stall in the Demon. What would be a good timing curve starting point to consider with the above listed parameters? The engine has 175psi warm cranking pressure in all 8.
The engine is still on my run stand.
Thanks FABO
Those numbers on the stand? I'm wondering if the idle will be a little different with the weight of a converter or a flywheel?
Darn right they will be and that's a good point.
There's no load. You can't use the numbers from no load to do much more than getting a sense of what the engine is like.
a. With no load engines will love lean mixtures and lots of advance to match.
b. At idle rpm the engine makes relatively little power. Any load at idle is a relatively heavy load for the engine. In other words at 650 rpm its a big jump percentagewise from freewheeling to placing in drive.
My sense from what you've posted is that your engine will work well with timing curve like Chrysler used to use (production) or Mopar Performance put in their distributors that were made in-house. Either will be a good baseline, then adjust/tweak as needed for fuel and other conditions.
Example here as Rick as he works through and posts the effects of his changes
And an example of how that changes a bit with different combustion characteristics
I kindof spill the beans on shaping the curve here
If you are stuck with a distributor advance that can't or shouldn't be shaped (eg MSD distributor) then use a manifold vacuum port at idle as a work around. I think your engine will have steady enough vacuum at idle to do that. But if you run it lean at idle, then you will kill it when going into gear; rpm will drop, vac will drop, and manifold vac advance will likely drop causing rpm to drop...
