Air gap intake and heater hoses
Magster65
Saanichton BC Canada eh.
Heater hoses. Sadly, we need them.
The plumbing isn't an issue, it's the looks.
I'm not sure why Eddy decided to put the 3/8" hole on the wrong side. I was going to drill and tap the 1/4" hole larger but I thought I'd check in to FABO before I do. How have you air gap people plumbed these? The one hose has to cross the rad hose...
I have my coolant temp sensor where your heater hose barb is now. (I used a reducer) and then my heater hose barb in the empty hole next to where your current temp sensor is. I plugged the hole where your coolant temp sensor is.
I'm wondering if the 1/4" i.d. is enough flow to still be 'hot' by the time the coolant gets to the heater core? If it is I'll just use the 3/8" hole.
I am pretty positive I used 1/2" and 5/8" hose on mine. 5/8" hose on the water pump and 1/2" on the barb. You can find fittings with the correct threads for the intake side with a larger barb on the other end.
On my airgap i drilled & tapped it next to temp sensor. Otherwise hose will go to far to driver's side. I did it for better aesthetics. Either hole will work.
it is a fair question, though. Why wouldn't Eddy do it right? I wonder if the Chinese knock-off air gaps have this issue???
I don't understand what Eddy "didn't do right". The 1/2"OD nipple has an ID just a C-Hair under 3/8" and fits just fine as pictured in the 1/4"NPT hole. No issue as far as I can tell.
yours looks just fine ^^^ . I have an Eddy Air Gap for a magnum, if I ever get to the project, i'll see first hand.
I just ran mine to the "wrong" side. Doesn't hurt anything at all. Pardon my grease, it's winter, I drive my car everyday, and I don't care. :p
I picked up the fitting today. I'll run it through the 1/4" and if there's an issue I'll drill and tap it to 3/8".
Thanks for the input.
