aengineguy
Every time I start my Dart I have a slight amount of belt squeal. I have one belt around the crank, water pump and alternator. The crank pulley is about 20% smaller than stock, made from aluminum, the water pump is also aluminum and the alternator pulley is stock steel. Current fan is a 7 blade SS flex, but it did the same thing with a cheap lightweight fiberglass 6 blade. It is a pretty radical 408 with 550-580 hp. I have the belt as tight as I care to push it and don;t want to result in bearing failure. Does not do it if I burp the throttle or nail it as the rpm is high enough for the belt to rotate all the masses at that point. I guess my choices are double the belts.....expensive change, spray some kind of sticky goo on the pulleys and belt, go to a clutch fan (put some slippage thru the clutch on start) or rough up the grooves a bit.
Anyone else have this problem. Any other suggestions?
Thanks all!!
Thanks all!!
