Yea I slept on it and thought it was a great idea.You know it! Or a 500. lol
If I did one like that, I'd build it to run through HP manifolds and idle smooth as a 383HP.Yea I slept on it and thought it was a great idea.
Might be much easier and more practical to sell/trade the car for a later A and swap the 408 into that...
Nope. @cosgig has info on that. I think he can show you how to modify yours for dual exhaust.Another question. Will the transmission crossmember from later A bodies fit the '63? The '63 is notched on one side for the exhaust. If I recall there is clearance on both sides of the later crossmembers.
RRR already covered it, but yeah you'll need to modify yours.Another question. Will the transmission crossmember from later A bodies fit the '63? The '63 is notched on one side for the exhaust. If I recall there is clearance on both sides of the later crossmembers.
there's a template on TTI's website to do it. you can print it out even!
I would buy the not fully dressed version, I have a 360 in my 65 Dart with aluminum V-Belt pullies and my after market aluminum radiator mounted to front side of the core support just to make room for a slim electric fan, I used Trans-Dapt motor mounts, got lucky and got them for $70.00 on eBay when everybody was out of stock and not available, and it is just my opinion but all that **** on the front in that configuration looks like it belongs in Grandma's SUVI'm not afraid of a good project.
No, 360 LA small block just like that 408 stroker he is thinking about. it is built pretty good, as I say NO SUBSTUTION FOR HORSEPOWER big or small blockBig block.
all that **** on the front in that configuration looks like it belongs in Grandma's SUV![]()
Sanderson Short Headers is an option, here are mine View attachment 1716468224View attachment 1716468227I also did a dual remote oil filters on a water jet cut plate then I powder coated it and mounted it on the front of the passenger side fender well and a modified bracket for alternator clearance of my oil filters.
Ya my buddy bought a BluePrint 440HP 383 stroker for his 65 Chevy stepside C10 and was looking at the same type and talked him out of it and saved him about $3000.00 and we still had issues with clearance in the front for electric fanI agree. The front drive components they offer is total overkill.
this is all I could findGood looking shorty headers. Any photos in the chassis?
TraceyAs much as I love Blueprint Engines, I cannot disagree. The accessory brackets are blingly and even in black they still look too chunky and just take up too much room. Of course, you have the option of not using them. The thing is, they'll almost give you such a good deal that it won't make sense not to use them. lolI agree. The front drive components they offer is total overkill.
Ya they offer that same engine in 3 or 4 different from no intake or anything to the bling queenAs much as I love Blueprint Engines, I cannot disagree. The accessory brackets are blingly and even in black they still look too chunky and just take up too much room. Of course, you have the option of not using them. The thing is, they'll almost give you such a good deal that it won't make sense not to use them. lol
Ya I went to manual steering kept the shaft just used steel bushings and u-joint (got rid of the headache coupler) , 4HP mini starter even tho I have short Sanderson headers, 10-1/2" clutch conversion linkage and Z-bar from Brewers, Eastwood 3 pass 22" aluminum radiator, and cut my floor and made my own 4 speed hump out of one from a C- Body and a 67 Chevelle for $50.00 refused to pay $200.00 for a tunnelI have a 340 in my 64 dart and everything is a pain in the A$$. I have power steering and a 4 speed with dougs headers. Well to be honest I had Wagons did most of the work and I think he was considering going Chevy after this. just kidding. You should also widen the radiator because you wont be able to cool that engine with the width of the 63 rad. I had to get a different ujoint for the steering, a mini starter, modified clutch linkage. oh and your engine compartment may be too short for anything fancy. The trans tunnel may be too small for a 727, even a 904 is going to be tight. Good Luck.
Very true and and a fun swap. Did exactly that in 1968. Ruined the 225 in 1963 Dart, so went to the wrecking yard and got a 383 w/833. Fit pretty good. Had to fab motor mounts, but that was not too bad. Only big problem was the headers. No room for exhaust manifolds or headers without cutting the fender wells, so had to go through the fender wells with custom headers. Bummer because I wanted to run B/MP, but the fenderwell cutting put the car into B/G, so not competitive. Got an off-the-shelf fiberglass tunnel kit from somewhere. Had to cut a hole in a fender well to access one of the spark plugs. I remember paying only $9.95 for the hydraulic clutch kit, master and slave. Didn't even widen the radiator opening, and the engine ran in the normal temp range. No steering mods needed. Great engine--bulletproof.If you just GOTTA have a V8.......Put an HP 383 in it and do something different besides the cookie cutter small block everybody does. It'll bolt right in with all the right parts and the distributor is up front and you don't have to hack the car up just to get a distributor to fit. Plus, you'll have a big block.
....and I said all that as a HUGE fan of Blueprint Engines.
