Brazilian Dodge Dart 76 (similar to 69 usa)
well, still have to weld a piece of metal.. clean everything and paint.
I think it will work :):):)
subframe rear end finished
Now I will follow your advice.. primer + undercoat.
did my best.
Next steps.. weld cracks on A-colum
hi guys,
sprayed some paint.. and I also used a sealing product.
will paint it black tomorrow as soon as I back home, after work
"nasty head cold"
is this a good thing or bad thing? (recall that, sometimes, English phrases does not have the same sense in Portugues)
"nasty head cold"
Here it's a bad thing. It's a slang term for a sinus infection, which cause nasty amounts of yellow-greenish mucous to run from your nose. Looks a lot like the seam sealer you used. My attempts at humor are getting lost in translation.
NOW everything makes sense! lol
HAHAHAHAHAHAHA
I have three of those.....they grew up some but they still leave a mess everywhere they go.
Did not work this week.
I came back from a symposium and had a lot of accumulated work on university.
I moved my car once again on parking garage. Now I have to weld the remaing cracks.
The problem is that I have to weld take an extra precaution to not damage the paint (just the real necessary).
You really can't overprotect from welding sparks! Wet blankets help,as do special foil wraps.
I used some high dense cardboard plates, wet blankets (not really blankets... some pieces of fabric) and rubber blanket
Passenger side (focus on lower crack)
not really a crack (I think).
Just the paint or body filler cracked (about 1/4" width).
Upper crack is body filler in excess.
