bronze gear
70wayfarer
new zealand
have changed to hyd. roller cam. do i need to change to bronze gear on dissy/oil pump drive. am efi so no dissy. cheers
I think you need the bronze gear... ( but beware ! you have to check the gear from time to time.. the cam gear "eats the bronze guy )
Greetings Juergen
^^ x2
If you don't know as the ones that made it. Many hydraulic rollers have std drive gears so you don't need the expensive and wearable bronze oil pump drive gear. But if you are not sure you can ruin the cam or spend a bit if you get it wrong.
cast rollers dont need the bronze drive (look at millions of 5.2's) , only the much harder $$$ billet roller cams. The gear on the cam is as same hardness as the gear on the drive.
Check with the cam manufacture.
In example, Crane came has came with grind numbers that end in "IG" which stands for "Iron Gear." There is no need for a bronze gear with those cams. But not all of there fans are like that and some need the bronze gear.
Hughesengines sell's a (Made by Crane Cams) distributor gear that is not bronze but made for what ever cam you decide on. It replaced the gear on the shaft you have. Stock or MP or other so long as the Dia. Is correct.
I do believe this is the gear to use with any cam reguardless of material. Someone correct me if I am wrong!
is this a steel /iron gear ? I have used a composite gear in my Pontiac Firebird a few years ago.... because of the cam
Greetings Juergen
Steel gear. It actually says it on the packaging, but it is hard to see only part of it there.
View attachment 1714953247 Hughesengines sell's a (Made by Crane Cams) distributor gear that is not bronze but made for what ever cam you decide on. It replaced the gear on the shaft you have. Stock or MP or other so long as the Dia. Is correct.
You are definitely not wrong, and in fact, that is the best gear made to date imo . It is not only melonized, it also appears as though it is burnished which softens the sharp edges which reduces gear wear.
Yup, just another example of inaccurate or outdated info from a magazine where someones first hand experience is more accurate . It is always best to check with the company that made the part irregardless of what is printed in a magazine . This is easy to do because all of them except for MOREL list their phone numbers.
CRANE CAMS
http://cranecams.com.au/pdfs/pp1110a.pdf
"Crane Cams now offers a new generation of precision
machined, specially coated and processed steel distributor
gears for popular Chevy and Ford engines using either cast
flat faced lifter or steel roller camshafts.
By using modern heat treating and manufacturing processes,
Crane Cams has developed a series of steel distributor
gears that are compatible with standard cast cams and
induction hardened and carburized steel roller cams."
