Kendog 170
Let the boy go !
So I removed the clutch pedal spring after diaphragm clutch install . I would like my pedal to return to top so I was wondering what light duty spring you may have used (part #) to accomplish this ? Second, my clutch petal is sliding off and jamming up causing me to reach under and push it back. So apparently the factory spring holds it in place so any ideas on that correction. I'm hoping to save my bad back from some pain if I have a game plan and the right stuff to get this done. The last time I had to work in that area I removed the bucket seat for access.I noticed the lower pedal results have been talked about but haven't heard about the pedal sliding almost out.
Thanks in advance
Thanks in advance
