Critique/suggestions on 273 engine build
If you go with spitfire headers you can order them now and that way you'll get them the same time next year.
You could always put in the 318, or 360 and dress it up to look like a 273. The average looker won't know the difference.
The 340 for my wagon will be getting Commando valve covers (compliments of Leanna's special powder coating) and a Commando chrome air cleaner. Will look just like a 273/235 motor but with 70 more cubes.
66DartGT,
Thank you for the info, people like youself are the reason I come to this site. I'll keep it in my file!
kcoyle - a later 318 will look very similar to a 65 273. The main difference would be the angle of the intake bolts. on a 65 motor, the bolts go into the heads vertically, on a 66 or later engine they go in at an angle perpendicular to the side of the heads. More or less parallel to the deck of the block. To answer your question the later 318 will bolt up perfectly to your cable shifted automatic. The only thing needed is an adapter ring for the crank register on the torque converter. A simple ring of metal is all thats needed. If you know someone that has a metal lathe they can turn one down for you in short order. I think there used to be an outfit called wildcat auto parts located in Washington state that has these adapter rings as well. google them or do a search on this site for them.
67 Dart GT 273 Commando. with A833 & 8-3/4 Sure-Grip so :thebirdm:
This engine has lots of good things about it.
-Mech Lifters
-Light Weight Adjustable Rockers
-Hollow Push-rods (Light)
-Forged Crank
-High Compression 10.5:1
-Small Combustion Chamber (57cc)
-235HP 280TQ from only 273 C.I.
My car:
-Bored .030 over (279C.I. or 4.6L)
-Heads Milled twice. (11.0:1 ?)
-Water Flow work Throughout Block & Heads
-Block & Head De-Burring / Mild Lightening
-600cfm Holley
-Dual Exhaust (with the Fucktarded Stock Manifolds)
-I am gasket Matching & Porting the stock Heads & Intake.
-Stock Cam
on 110 it has Pulled the Wheels off of the Ground...
I am planning on Purchasing
-Eagle I-Beam Connecting Rods (I Cooked 4 of the Rods when I spun the Bearings... I was PINNED doing 111MPH for 1 Minute then tried to limp it 25 miles):snakeman:
http://store.summitracing.com/partdetail.asp?part=ESP-6123CB&autoview=sku
Possibly get:
-Hooker Comp Headers HOK-5901HKR for $169 from Summit http://store.summitracing.com/partd...7+4294888795+1005+4294923429+115&autoview=sku
-and the 3" turbo Exhaust kit from summit
-COMP Cams 20-246-4 with 270 adv dur .468
I DO HAVE POWER STEERING!!! I hope the Headers will work without Any modification... WHo the F knows though right?!
-Mech Lifters
-Forged Crank
My car:
-600cfm Holley
-Stock Cam
Possibly get:
Yours is a 67, those headers will not work on a 64 and you may be better off with some other headers. I have those. I'll sell you mine if you want them.
Your heads will probably crack soon enough, they do that.
The 3" exhaust is way too big. 2.5" tops, probably better with 2.25" and an X pipe, but good luck.
No disrespect to the 318, but I never understood why someone would change to a 318 when they could put a 360 in for around the same cost.
No disrespect to the 318, but I never understood why someone would change to a 318 instead of a 340 or 360 ?
It depends what you want to do with it. With a 300-325 hp build the 318 is perfect.
340's are not cheap and the 360 has external balance and is not needed for this power level.
The 318 is one of the most dependable engines ever built.
Have you checked out some of the cars running 318's in some of my other posts?
A 318 with a stock bottom end is virtually bullet-proof at this horsepower level.
You are right, and I agree 100%. (Depends what you want to do with it).
But if you want something with some oomph the 360 would be the choice over the 318.
And like I said right around the same money to build. Actually might be less.
I had a great running 318 in my Dart.
340 manifolds,Ede Performer,Ede 600,Elec Ign,etc. Car was a lot of fun to drive. Havent run my new 360 yet so I cant comment on it yet. But it should be very dependable, and should dust the teen. If it doesnt I would be very dissapointed.
Well consider this. The OP has a very light 64 Barracuda. Even stock 318 low end torque, as you know, will roast the tires.
He already has a 273 sitting there to scavenge parts off of...mainly the crank and heads. If he uses the stock heads from the 273 with bigger valves and a good valve job and maybe does a little clean-up on the ports and valve guide areas, they will work great and save him money. Honestly, the 318 heads are fine, but the 273's offer cheap compression. The 318 crank and the 273 crank are both 3.31" stroke so that is not an issue unless he needs a new crank for the donor 318 and the early 318 and the 273 cranks are forged. The 360 never even came with a forged crank, though you don't really need one at this level. The stock 318 rods are fine too.
On top of all that the 318, with it's way shorter stroke and better rod ratio, revs quickly and freely past 6000 rpm with no problem.
I just have to admit, I really like the 318. It's a great motor and he'll even get better mileage with it.
I suppose an argument could be made that you could run less gear with the 360 and then attain the same mileage, but you would have even worse traction problems.
It's probably gonna come down to money and availability and if that's the case the 318 wins hands down.
P.S. Johnny, you do nice work.
Click this link and take a look at the CARS WE RACE section. click on the 2000 Sebring and the 71 Demon 340. The 340 car won't run with the 318 Sebring. It does weigh 130 pounds more and has less tire...but check them out.
http://www.bobmazzoliniracing.com/
Checked out your site. Looks like you guys are building some quick cars.
If I lived in Florida,I know where I would be spending a bunch of my time. 8)
Funny the twist's these post's take, so I went back and looked at the original post.
He never really told us what he wants to do with the car. So...................
Thanks for the compliment.This is my 2nd Mopar build.
My first a 65 Dart Conv, turned out a Spring Fling Winner out here in Cal a couple years back.Was a great honor. If all goes well, maybe I can get another with the Swinger. 8)
So which size are you headers than? 2.5? That is what I would really like for now.. My car runs on High Octane and Hope. :angel7:
It ran well and I hope it will keep busy. All I ask is to smoke my buddies S2000 a few times to make him look like a fag and Have an Awesome 67 Sportscar. It Handles well and stops like a Mo-Fo!:snakeman:
I have made grown men cry going into corners sideways coming down into 3rd gear... it rolls on 225 60 R14s & 245 60 R15s I love her and I'll see you guys out in Santa Cruz CALI where the Roads are Curvier than the girls...
Just a question for the group - does a 273 have no value? It would seem to me that someone out here doing a resto would be in the market for a nice low mileage 273 that could be test driven and then dropped in their car...
Rather than dismantling the 273 to build a 318, there would be money to get the parts for a 318 or 360. Just wondering...
Thanks,
C
Well, there are a couple 273's on craigslint san diego for $50. I've seen them for free. So to answer your question, a 273 really has no value. I did see a Barracuda on the net somewhere a few years ago with a 273 that was really making big power, but it had a lot of custom parts and money into it. There's absolutely nothing wrong with a 273 for just a regular driver.
The headers have a 3" collector and, on mine, reduce into 2.5" duals. The headers will be alright on yours, but you will probably give up low end torque as a trade off for top end power. If you run 3" pipes all the way back, the torque loss will be higher. I think a 2.25" exhaust would be the way to go on a 273 and the X pipe is just better than true duals.
Have you considered changing to a little hotter cam? Something with similar to stock duration and a bit more lift? I think that would help more than headers. Also, the headers are gonna add quite a bit of heat under the hood.
As far as your buddy with the S2000, he already looks like a fag!
Man! That thing looks killer! Do you still have it or did you sell it and move on to the next?
Still have it.
Its an original Hurst 4-spd car. Slant six,now with Clifford intake & Header.
Ede 500 cfm,electronic ign,disc brake,pistol grip. Didnt have the heart to pull the /6.
IF you could get an honest 350hp from a 273, it would be a PIG on the street. It would need 5.38 gears and a tiny convertor or 4 speed and would have a very narrow powerband. Gee, you could get that with a junkyard 360 with a cam and a little head work(and I do mean little). Chivalry is dead, embrace the modern days.
This bothers me in a way, I always hear everyone knock 273's for not being able to run.. Here's my just of my combo, it runs mid 7 seconds in the eight mile, and I drive it about a thousand miles or so every month.
-Block Bored .060"
-Stock replacement Badger (discontinued) .060 oversize 10.5:1 pop up pistons. Valve reliefs cut .110" for P-V clearance.
-Deck milled .030", lined bored, main studs, windage tray.
-1969 340 rods and crank, balanced.
-302 Heads, 2.02 Valves Intake (notched bore for de-shrouding), 1.60 Valves exhaust, ported and polished, angle milled to reduce chamber volume to 51cc's Head flow is at 220Cfm's on the intake @.550lift
-Compression is just over 12:1, and about 240 psi cranking compression.
-M-1 Single plane manifold, ported to match heads
-Quick Fuel built 850Cfm carb, 1-inch open carb spacer
-Custom Ground Solid lifter cam: 320 Advertised Duration, 252@.050 tappet rise, .510 lift at valve, 108 Lobe centers (intake and exhaust)
-Stock style Isky replacement Iron adjustable rocker arms, 1.5:1 ratio, Isky hardened Pushrods.
-Headman Hustler Fenderwell Headers, 1-7/8 Primary tubes, 3-inch collector, 2-1/2 exhaust to dual Flowmaster race mufflers.
The car is a 1966 Dodge dart, four speed, HAYS Strip Clutch (10.5 ofcourse), and a 8-3/4 packing anything from a 3.23:1 SurGrip, to a 4.89:1 Spool. But I usually run a 4.10 SureGrip for best overall performance..
With this set up the car is (in my opinion very diveable) for a car of its manor. I run it on 100 octane 76 Pro-Power Unleaded (there is like two gas stations left in my area that still sell this stuff) or 91 Octane with a little VP 110 octane mix. If I'm not beating on it, and its just being driven around it can be driven on just 91 octane (the car has a stock rebuilt 4-core 22-inch radiator and engine temp must be below 180). At 3,200rpm and with a full belly of just 91 Octane my wife and myself drove this car from Los Angles Ca, to Santa Cruz (in Central Ca) about 260 miles each way on our aniversary this year in January. No problems, whatsoever...
I'm hoping this help prove alittle bit that a 273 can be more than a dog.. I will say though before the car was a stick, the slush box made it a bit soggy on the low end, (burnouts where only done from a stand still start only w/no foot braking).. And it took me SIX difrent 273 set ups to figure out how to make it run.. My first 273 only made 145 Horsepower to the wheels! This on makes 371 @7200 rpm's.. Torque is around 300 @ 2500 rpms, and peaks out at 407@ 4600-rpm's I will try and post some pics and a vid sometime this week of this 273 engine in my Dart..
Hope this can help..
:cheers:
It's a toss-up...
What I want is a good running, mildly above stock 273 commando for my 65 barracuda project.
I have a 273 commando in the machine shop and I have questions. The block is .030 over with .030 domed pistons (previous owner) and is ready to go. ( all is or will be balanced) I will be running a 904 with a mild shift kit (runs like stock until you "call on it" and it is supposed to crispen up a bit)
  1. Q1) stay solid or go hydraulic? roller?
  2. Q2) domed or flat top?
  3. Q3) what cam?
  4. Q4) intake?
  5. Q4) what other factors? Heads?
I want the engine to look as stock as possible, may even just dump all ideas of pepping it up and go stock, but I still feel the need to improve a bit. I have pertonix, original carb (rebuilt) and am planning an 8 3/4 3.55 suregrip but that is debatable. I will be running the Formula S stock exhaust with resonator tip.
All advice appreciated!
Again, I want a stock appearance that is dependable and will squeak the tires if I have a notion to. Most driving will be cruising, not racing.
Thanks a-bodies family!!!:-D
-Block Bored .060"
I'm hoping this help prove alittle bit that a 273 can be more than a dog.. I will say though before the car was a stick, the slush box made it a bit soggy on the low end, (burnouts where only done from a stand still start only w/no foot braking).. And it took me SIX difrent 273 set ups to figure out how to make it run.. My first 273 only made 145 Horsepower to the wheels! This on makes 371 @7200 rpm's.. I will try and post some pics and a vid sometime this week of this 273 engine in my Dart..
Now that's the way to build a 273! Look out 360s!
Listen.... I was trying to be nice:toothy10: since you stated "I know everyone is going to say go with a 360" but I think everyone else has expalined.
I've tried the 273 route before as a power builder and yes the the motor came with the car. Click on my username go to my threads I created.. you will the plees for help on making power with a 273... everyone is right believe me ... don't sink another penny in that motor!!! I gave my entire 273 motor away!!
360s have longer stroke cranks...
Save your money while you still have it in your pockets...
I have a pretty mild 360 (compared to other members motors) and love it yes it was extra money I know... but I love it!
Here is what I think of the 273 :thebirdm:
Well you got some anti D-Dart dudes who know how to abuse, not use a true 273 / 285hp D-Dart engine. If you go to a 340 or 360 it will not be a true D-Dart. There are so many guys out there with 440's rather than Hemi's because they can't afford better. You know the old saying toys for men or boys. I'm in Florida with a true D-Dart bring on your 340's & 360's My baby is tired of chewing on Mustangs. Put this lip service aside and consider this . . . anyone can buy a 340/360/327/289/283 to hot rod with. Building a true Mopar 273 into a super stock with all the bells and whistles and you have a special Hi-Po from the past. In your car from the past.
Great job d/stockdart! That's what Hot Roddin' is all about!!! That's why people still run Nail-Head Buicks, FlatHeads, and Poly 318's. It's Kool Stuff! Otherwise we'd all just build 350 Chevy's and be done with it if power-per-dollar was all that counted. But it's NOT, and Thanks God For That!.... just my humble opinion
I just had to respond. If you want a low buck tire-shredder put in a 360. A 318
will still provide a lot of bang for your buck. If you've got your heart set on your 273 go ahead and build it. You can go as radical as your checkbook will allow.
Your 273 will always be impressive for what it is but here will always be something out there that is faster. If you bore it more than .030 have it sonic checked because core shift is pretty common with the early LA blocks.
Egge has cast pistons listed in both low and high compression and Flatlander Racing has forged pistons listed in any bore size and compression althoughI have never talked to either company to find out for sure what the offer. I am
a fan of solid lifter cam. I like the clatter of the solid stick (it's all part of the character of the engine) and depending on how much and how hard you drive it
doesn't require much adjustment. Isky E-4 comes highly recommended. Schneider also has a mild solid lifter stick. Both are available through Flatlander.
You could also contact Comp Cams or Hughes and ask them what they would recommend. I wouldn't go more than a 268/485 in the little motor. A hydraulic roller would be fun but more costly than the solid cam.
The stock crank is perfect as are the stock rods as long as they are both checked, machined and balanced. Don't forget new rod bolts.
The cylinder heads are good for the 273's small bore. Have them surfaced (not milled a bunch) and gasket matched and a bit of bowl blending done. Slightly bigger valves would help but too big is no good for the 273's bore.
The rest of the pieces arent too special, timing chain/gears (all metal and double roller if you wish) Oil pump (I like high volume), a windage tray and/or a deep pan, etc. etc. Stay around 600-650 cfm range for a carb and depending what year your cylinder heads are A street intake to fit. 273 intakes are hard to find. The stock 4-bbl one works ok with a little port matching and grinding but they are quite heavy. For any kind of performance headers are a must. There are many posts on this site about the different brands. Find BJR Racing on this site. He is a guru on small blocks and has built some screamin' 318's. Maybe he has some ideas for a 273? Bye for now and good luck. toolmanmike
Allways a good subject for discussion! LOL
hi bushmakers 235/273 stocker in K/SA only runs 12.00 @ 110 mph. thats .95 under the index.
I have about 12 time slips from 1966 when my "TRUE" D/Dart was raced. At that time, it ran a best ET of 12.92 and best MPH of 105. Not bad from a little 273. That was on 7 inch Racemaster cheater slicks and 5.30 gears.
I'd say .... build it.
