start here going clockwise 1,8,4,3,6,5,7,2.
Everything is working as it should be.
Two cylinders are not firing, so this is not an accurate statement.
Rusty rat rod could have at least said bye like dart273 did hahahah
Lol! Where's peoples class nowadays? Sheesh
I was wondering the same thing. I very rarely use the smileys on this site and have never used that bird flipping one. It's just rude. Nor would I have talked to someone like you did who was trying to help. I hope you get it fixed. If you do, it will be without my input from here on out.
Oh and goodbye.
A leak test is when you loosen the rockers back and blow air into the spark plug hole right? If air is coming through tailpipes, its a bad exhaust seat. Air through the carburetor is bad intake seat, and coming through crankcase breather is rings. Or is that something else? lolTypical order of misfire diagnosis;
1- check spark, you said you did this.
2- check for vacuum leaks, you said you found no external leaks.
3- check compression, you said you did this.
4- perform cylinder leak-down test. You didn't mention doing this(unless I missed it) so I would recommend doing it if you haven't. It will tell you much more than a compression test will.
5-verify your ignition & valve timing (individually) aren't fluctuating because of mechanical problems. (Worn distributor, timing chain or gears, camshaft etc).
Take a vacuum reading with a gauge connected to manifold vacuum & watch for flutuating needle & low vacuum.
If you still suspect a cracked intake manifold or other vacuum leak you can get an ordinary propane torch & feed some propane into the air cleaner or top of the carb while the engine is running & see if it smooths out or stumbles worse. Smoothing out would indicate a lean condition(like a vacuum leak) & stumble worse would indicate its over-rich.
I would suggest either replacing or thoroughly cleaning the plugs before further diagnosis since they may be fouled due to the misfiring & may not respond to any of the testing correctly.
You need to approach this issue with a more clear & precise method rather than tearing into it & making guesses.
I hope this is of some help to you. Good luck.
Don't fall into the trap that just because the parts just came back from the machine shop or just came out of the box that they are okay. Even the best machinists can have a bad day & make a mistake. I don't rely on compression readings alone because the tester only reads peak pressure. A leak down test will tell you everything a compression tester can & much more. I've seen too many engines with bad valve springs or seats leaking that showed up in a leak-down test but had good compression test readings.A leak test is when you loosen the rockers back and blow air into the spark plug hole right? If air is coming through tailpipes, its a bad exhaust seat. Air through the carburetor is bad intake seat, and coming through crankcase breather is rings. Or is that something else? lol
I havent done this yet. Wouldnt bad rings give me low compression? I know my seats are ok. These heads are rebuilt and never ran.
Try this and it won't cost you a dine.....maybe a valve cover gasket if it gets damaged.
it will only take you 10 minutes and save you a set of intake gasket and a lot more then 10 minutes
loosen the right rear rocker shaft bolt, 1/2 of a turn.
Do the same to the left front rocker shaft bolt.
start it and see if them two cyl come to life. if they do you can buy some rocker pedistal shims and fix the problem or spend the $$ to buy some pushrods that or .020" shorter.
if neither cyl come to life, then take the intake off just to be sure.
^^^^^^^^^^^^ try this,, it is a good lead,, been there..
Ill give it a shot man thanks! I dont think its a machining issue though because ive had 2 different heads on the motor and am having the same issue in both head sets. The only thing i havent actually fully played with is the intake.
Actually, now that i think about it, thats not it lol. I purposely mied the pushrods and lifters around in the engine too. (i know thats not recommended) I still had the same issue. Same 2 cylinders acting funny... Crazy lol
Hahaha! I justmcaught that lol.:cheers: Yea ill give it a shot man. I'm not saying that's NOT the problem. I just thought that MIXING (lol) the pushrods around would put the misfire in another cylinder. That's what my buddy thought it was. He thought i had a slightly larger pushrod in one valve. But I'll definitely check that! Would it be noticeable if the lifter was compressed all the way? I'm just curious. :newb:You did what with the push rod??? Not making fun of your spelling, I'm probably one of the worst offenders here!
Ill shoot some pics tomorrow. from what i know i ts a factory hydraulic setup. Ill start measuring stuff as well. Thats a good idea.Get a factory service manual for the specs and start MEASURING things like the push rod length, lift at the cam, lifter length, valve spring installed height, valve length, rocker arm ratio, etc. until you find something that doesn't add up. Do you have solid and hydraulic lifters mixed up on the cam?
Pictures would go a long way here......
I meant visibly... Will you be able to see the lifter compressed all the way.Yeah ! ! .. it'll run like yours.. lol
