You guys are all whistling Dixie thinking they'll work
Bwa ha ha ha ha ha.....
You guys are all whistling Dixie thinking they'll work. Read post #20 from SydCuda. Sharpie said he measured his car from between the shock towers and it measured 28". He also measured how wide the engine was with the Dakota headers installed and it was 31". Where you gonna put that other 3 inches??? Just look at the picture where Strokerscamp showed stock manifolds fitting and you'll see they are super close. I know for fact the Dakota shorty headers stick out a bunch farther each direction than stock manifolds because I owned a 93 Dakota and installed those shorty headers on it. They took up a lot more space (stuck out farther from the engine) than the stock manifolds.
I'd gladly pay 250-350 for a pair myself but I just cant justify 600 bucks right now for a pair of tubes. Not saying they aren't worth it, just that I'm not willing to pay it...I dont know about you but I would gladly pay up to 250 bucks for a well fitting stainless set of headers even if they were shorties I just want to get cruising ASAP!!!
i wonder if they fit early a's too....
If you want to remove shock tower material to fit the dakota headers It appears that you would need at least another 1 1/2 inches off the shock towers to fit the headers. Im with you on the dakota manifolds I couldnt swear it but I am sure their flow rates are much better than 273/318 manifolds and 60 or so bucks for new manifolds isn't bad. I will build a 408 out of a 360 magnum eventually to replace the 360 mag I have now and will at that point asses the exhaust system again but for right now it's going to probably going to be maintenance free, frig free exhaust manifolds. As far as smog ports are concerned the part numbers for the two manifolds in the previous post do not have smog ports on them. There are manifolds available with the ports but if you're hanging them in a smog exempt A body I can't see any reason why you would want them.
has anyone seen this variation on the dakota headers? they look a slight bit more promising, yet they are $335
http://www.summitracing.com/parts/EDL-65643/
Looks like I'm gonna have to go this route, these "look" to be less restrictive than my 318 stockers. My Dusta sits low and as I stated before, can't bust 600+ for some headers right now... Thanks Dustoff440... haven't heard "dustoff" since I left the Army...For those of you who want to use Dakota manifolds It looks like the best streamlined manifolds with the least amount of bends and restrictions and also hug the block best, best all around are Dorman 674-538 and Dorman 674-271 which are available for approx 65 bucks each new.
I had a couple people interested and wanted me to post pictures of the manifolds, so here you go. Sorry it took me a while, my camera batter won't take a charge, so I had to use the Mrs. camera.
Just to be clear, these will fit your car but not an early A-Body. Correct?
