CudaFactHackJob
I stopped there for gas once; I think maybe I bought some chips too..
Vegas is a strange place - it was hell trying to find good shops and there's not many shops to begin with. Or maybe the good ones don't advertise?
Almost everything I ever paid to have done there cost 2-3x what I paid in AZ, WA, or ID.
Get that 727 apart yet? post pics!
Do the new shafts from Dan's or Adam's come complete with new U joints and yoke.
I don't know I bought the car and with the car I got a 727, 8.75, headers, exhaust, floor shifter (minus torque shaft), 73+ front end, 489 case, gears and sure grip. He offered me all of the spare parts he had with the car (for more money than I paid) but I don't have room for 2 cars in my garage lol.
Yea that is why I asked about strange engineering DS and or using another shop. Dans said it would be close to 100 to shorten my shaft.
I have bought several ds from Dan's including 2 aluminum ones
No problem.
I have bought several ds from Adams also. Again no problem either.
Gotcha on the 7.25 to 8.75.
Just so you know, I had the trans yoke but had the shop replace or build everything else.
This new shaft is 7290 Ujoint DOM steel, guaranteed for up to 600hp and was about $380.
Not here in Las Vegas though right?
Ps heres the 727 in all her glory.a little dirty but I think it's in good shape. Majority of the other parts have been dirty but in good working condition
I used Dans went I had a friend working there........and now I use Adams cause a friend knows John,,,,the guy that does the driveshafts.........quality are just fine at either shop,,,
See who gives you the best deal.....
Dont worry about the 7260 Yoke it is more then enough to do the job....
If you need help with the rebuilding the 727.,,,,,,I got all the little tools you need.....bushing drivers...clutch pak compressor tool....etc
Red fluid is a very very good sign! I'm not suggesting you rebuild it; just take out the front drums to check on the two clutch packs that are up front; and the front band; that's ALL. But with red fluid, that means it's probably good to run as is. How far does the input shaft pull inward and outward? Over 1/8"? Have you had the pan off to check for debris in the bottom and in the filter? Inquiring minds wanna know...Post pics of the bottom of the pan..(AFTER it's off..) And the filter too; top and bottom.
$450-$500 on the day you pick it up? LOL..nobody is gonna re-use ANYTHING. That's BS.
Answer is easy, measure and order the Strange shaft from Dr Diff. 350 for brand new precise quality piece .
I have had shafts shortened/ refurbished from multiple vendors/shops None are as good.
Call Cass at Dr Diff, you wont be disappointed.No 350-400 unless they can reuse my joints/yokes then possibly cheaper.
I'm going to try and make it in there on Monday to get shafted
