Dyno time
hotrod68
hayfield mn
Any guesses? 400 based 512, 440 source kit with lightweight crank, 14to1 with indy 440-1 heads howards solid roller 283-285@ .050 .675 lift indy intake with 1050 methanal carb. Its the 230 coldweather block that is half filled with a stud girdle and billet main caps.
I’m gather parts for a 499ci mild build , I have the block and 4.015” eagle crank, eddy rpm intake, and headman headers. I’ll Probably use the 440 source rods and pistons. Not sure on cam and heads. I would like to find some aluminum heads and probably do a roller cam if I can.
740 HP at 6500
690 tq at 5900.
That should be a real ripper.
4150 or 4500 carb ?
I base my guess off of 685 from my 470 with 13.0:1 way smaller flat tappet cam & trickflow 240s, but I do run a tunnel ram/ 2- 850s .
My peak HP 5800 and tq 4900
740 HP at 6500
690 tq at 5900.
4150 or 4500 carb ?
Youre the closest, it made 798hp at 6700 and 712 tq at 5900 4500 carb. It would go more but we ran out of carb.
dang I was way to conservative I guess on the rpm I didn’t think they twisted up that high. I was thinking a 6k red line. You guys are building true monsters.
More carb and probably rpm with that large 50 number on the camshaft, probably get in the 800 range I would bet ! I would think with that large 50 number camshaft and heads that dude will rpm on up there !
Nice. Who built the motor? Who did the head and intake work?
