From the files of the WTF were you thinking dept.
There's a few of these on YouTube. They all end up the same. Screaming, yelling, threats, cops, arrests, etc etc etc
I still remember many years back a young single gal, likely college?? moved into the duplex across the street. I have no idea how she thought she could afford that. I don't recall a partner/ roomate, but maybe. Anyhow one morning I woke up to the sound of an unfamiliar truck, look out the bedroom window, and here's a wrecker hoisting the *** of her car. The just drug it off, front tires screaming. Guy has to wonder, other than tire damage and the risk of fire, what the transaxle had to say after that........................
I always thought about that too, then realized dragging tires is not much different than a burnout, unless the tire starts hopping. Noy the transmission parking paul might not be happy!
Not only did he loose the car, he is now going to get sued for the damage to the 1/4 panel that he caused.
I'd assume that once they are in the clear they pull over and re-rig, put dollies etc.
Alan
I was thinking of a way to reposses cars.
Make a wheel dolly that you you put behind the wheels and when you pull the car back the car flips the dollies a few degrees and sets the tires on the dollies.
Would work best if you put them under the non drive wheels and pull from the other end
"Dodge charger owner tries desperately to stop his car being repossed"
Erm, no
That was NOT his car
