Sorry to hear, wish I could offer you some help! I'd be there wrenching with you with a few left-handers as well!!
Thats what I'm thinking...From what I can see, there is no hardcore scoring to the crank, or any of the main/rod caps...
EDIT:
It appears the rod bearing actually "spun", and wore the little tab off that keeps it in place, which probably means I can't re-use the rod, since it might not hold the new bearing tightly, and will just spin again...hell i dont know..
Well, I got all the bearings pulled, was pretty difficult with the crank in the engine...lol. 1/2 were good, the rest were hammered...I hope it will be easy to slide the new ones in. My rod cap cleaned up decent with some emery cloth...
Tonight I will polish all the main and rod journals...what a tedious little job to do in such a limited amount of space, about a foot from my face as I lay under the car on my back., oil dripping in my eyes... LOL
You guys are gettin' hosed on beaters out in cali...
Ok-- Plan B, find a hard up krack head with a car needin' uh fix, don't tell me theres no krack heads in cali...
Just so you know, that tab does nothing to keep the bearing from spinning. It is only there to properly locate the bearing and that's all.
Stroker, your kidding, right? The tabs lock the bearing against the non machined mating surface. If they just laid in there with no positive lock mechanism, they would all spin.
If you are up to it, stake the rod side bearing with a pin, like a piece of a drill bit. Drill out about 5mm deep and hammer the next size drill bit in there and then grind almost flush, leave enough to catch the same sized hole in the top of the bearing, dont worry about the bottom, it aint goiing anywhere. You are doing this on your driveway right...with a time limit? Think of a derby car between rounds.. Just get 'er done!
push the rod up some , pop the old bearing out, run some emery cloth over the journal, stick new bearing in and cross you fingers.
You got me, Bro. Ill file this.
Man there's no way I could do what you're doing. Working on cars is the last thing I can do under pressure, guess it's why I'm not a mechanic lol... Every repair "task" I've tried has ended many days later than planned.
In fact I need to replace the blown clutch slave cylinder in my Jeep but have been putting off the work until I get the new part, and even then it probably won't be until Thursday I get it finished.
I agree.
Rob is the man when it comes to stuff like this.
Great guy to get good info from.
Thanks, but believe me when I say opinions vary.
Yeah, Rob I respect your knowledge very much, but don't totally agree with this. I agree bearing crush is the one of the determining factors on a bearing spinning, as my previous post said.
But I have had the tangs hold them, prior to them spinning, when they have lost their crush.
The tangs are located opposite, on each half, and hit on the other half. I believe it is the metal losing it's properties, after losing its crush, that finally let the tangs release. The crush actually forces the tangs out into the slots in the rod.
After 45 years of dealing with this issue, I am not buying that article. I have torn down too many motors where the tangs were still holding bearings that have lost their crush.
I used to help with an alky aluminum rod motor, that had pins, that kept the bearing from spinning.
