kingvern
408 stroker,
Fully cnc ported by hughes engines edelbrock rpm's, these flow Intake312.3 Exhaust 218 @ .600, port volume 225cc, 65cc chambers 5 angle race grind on the 2.02 1.60 valves.
Harland sharp roller rockers 1.5
Edelbrock super victor fully ported by hughes
Pro systems venom II 950cfm carb
Lunati solid flat tappet drag race grind 255/255 @ .050 282/282 advertised, 582/582 lift
Eagle forged rotating assembly 11.28.1 compression
cloyes timing set
Msd distributor with FBO ignition
Milodon pan, pick up and windage tray.
cloyes timing set
