your running too much total dan, back it down to 34 or 35
yep - you'll melt your slugs......
Description: CRS 280-0H - Hydraulic-Use in 340-360 Street Machine. Dual exhaust, 3.53-3.91 gear, 9:1 compression. Headers & aftermarket intake, 2500 stall.
Cam Family: Magnum Hydraulic Flat Tappet Camshafts
I find this thread quite confusing and misleading anyhow.....
heres another concern bjr,read the cam card and tell me if it makes any sense to you as written.all 360s came with 72 cc chambers so at 0.60 I would seriously doubt valve shroud with the aeroquips.kb 167 pistons would have brought you to zero deck just milling the heads a lil. compression or in machine shop lingo swept volume is ok but the cams too small imo for a 2.02 360 ported head, I would use around .525 lift for max velocity with these heads,check valve to piston and piston to head clearances,if valves arent within specs ya can flycut reliefs in the pistons.I think your carbs too small, try a 650 holly dp.only thing I agree with here is subline on the airgap intake and the 1.88 360 head. As I stated I have a set of 76 360 heads in good condition with the 1.88 int 1.60 exh.free. whole combo is wrong imo.if that cam card does make sense to you bjr your gifted. yeah ,I can see where its misstated also. give aeroquip a call dan and give them the combo your running and see what they say. bigger carb and .525 lift area cam and the airgap intake should take you to over 400 hp, stall in the range of 3000 to 3500 imo, any comments BJR?
318 bored .30 over yours is .60, no big deal
KB167 pistons set to 0, there are a few ways to achive this, square deck the block, or save money and use a mopar thin head gasket.
360 1.88 (596) heads or the better Magnums
Comp xe268 cam
600 cfm carb
Air-gap
That is a basic combo that will get you in the 400hp range.
HOw does cam lift max for max velocity?I would use around .525 lift for max velocity with these heads,
