HankRearden
How many gears does the Hyundai have? And is it an AWD? Those will make a big difference early in the run.
If it's an, 8 speed AWD, you are probably screwed.
I believe it is awd. I'm almost certain its a stick but can't swear to it. I believe it is awd.
Ouch, i was afraid of that.If it’s a new G70 awd you will get roasted on the street… they run into the 12s on dirty pavement…you probably want to be running at least mid 12s to have him covered
