Brambles
How much oil pressure does your engine produce at idle when fully warmed up??
Since my engine was rebuilt I have run a stock volume pump and for the first few months while breaking in the motor it had about 25 psi at idle fully warmed up.
Now with 14,000 kms on it ( about 9000 miles I think) the oil pressure at idle is 10 psi. and cruising on the hwy at 2500 rpm its about 25 psi.
I'm told that its still within acceptable specs but its on the low side. The engine doesn't knock at idle so the bearings are still floating in oil.
I want more oil pressure and am wondering if putting in a hi volume pump will boost the pressure up to desired levels? I don't know about Hi-pressure pumps but have always been told not to use them.
I'm going to tear the motor apart and see if I can tell WHY my pressure is low but for now its just being parked.
Any ideas?
Any ideas?
