How big a torsion bar nick is ok?
Suspension, Steering and Chassis
  1. Backally
    Backally FABO Gold Member FABO Gold Member
    581
    335
    Sep 4, 2011
    Wisconsin
    Local Time:
    11:05 AM
    D7ACBC0E-6D74-4FE4-AEDA-0F917CB601DE.jpeg Found a set of torsion bars in my garage. Before I sell them, how big a nick is acceptable? Can catch a fingernail on it
  2. 72bluNblu
    72bluNblu FABO Gold Member FABO Gold Member
    11,911
    6973
    Nov 28, 2008
    NorCal
    Local Time:
    9:05 AM
    That’s junk. Also why you never use vice grips to remove a torsion bar you want to use again.
    • Agree Agree x 1
    • MoparMike1974
      MoparMike1974 FABO Gold Member FABO Gold Member
      3,556
      2908
      Jun 16, 2017
      Maryland
      Local Time:
      12:05 PM
      Smooth it out with a sander to get rid of the stress risers. Should be fine.
      • Agree Agree x 2
      • Disagree Disagree x 2
      • qkcuda
        qkcuda Well-Known Member
        1,581
        1716
        Mar 6, 2013
        Jarvis, Ontario
        Local Time:
        12:05 PM
        I had a spot like that and dressed it with a file and have been running them for years.
      • 72bluNblu
        11,911
        6973
        Nov 28, 2008
        NorCal
        Local Time:
        9:05 AM
        Nope. That bar is garbage.
        You have to understand that the vast majority of the load on a torsion bar is carried on the surface. That’s why things like hollow sway bars work just fine and actually aren’t usually much larger in diameter to have the same rate.
        That’s a damaged 45+ year old spring, and it’s damaged in a spot that’s critical to its function.
        And how many miles? You put 50k miles on it yet?
        That bar is junk.
        • Agree Agree x 1
        • jos51700
          jos51700 Green Bearing thread connoisseur
          6,058
          2851
          May 24, 2009
          Bel-Ray
          Local Time:
          11:05 AM
          Properly dressed, corrosion inhibited, and safely loaded, it would be fine.
          Do you have the empirical experience to insure those things? The cost of a catastrophic failure versus the cost of a replacement bar..... not really worth it.
        • Backally
          581
          335
          Sep 4, 2011
          Wisconsin
          Local Time:
          11:05 AM
          Found them in my garage, didn't even know I had them. Cleaned them up to sell them and found this. Not going to sell them to someone if there is the possibility of them failing on someone.
          Thanks
          • Agree Agree x 3
          • Like Like x 2
          • Daves69
            Daves69 Well-Known Member
            6,101
            4672
            Feb 20, 2011
            WestOfChi
            Local Time:
            11:05 AM
            Maybe take a poll on who would buy these in the as pictured condition.
            • Like Like x 1
            • 72bluNblu
              11,911
              6973
              Nov 28, 2008
              NorCal
              Local Time:
              9:05 AM
              You mean, properly dressed, corrosion inhibited, and safely loaded, that bar would not perform as designed. There's no proper way to fix that bar that results in working the way it's supposed to.
              When you damage a bar like that with a compressive force, the metal under the damage is compressed, which also means hardened. So, even if you smooth out the nicks, you have hardened metal in those areas where stress risers will still form. So you have to go deeper than just the nicks.
              Then, you have a section of bar that's at a smaller diameter. The outer diameter of the bar is key in determining the spring rate of the bar. Just look at how much difference a few hundredths of an inch make on the rate of the bar.
              For the A-body bars you see .02" make a 10 lb/in difference in the rate. What will it take to clean up those nicks? Now you have a section of bar operating at a different effective rate than the rest of it. You think the overall rate of the bar is going to be the same? Do you think that the section providing less resistance than the rest of it will cause metal fatigue/stress in the area it necks down?
              Sure, if you smooth it out enough you might not get a big crack to propagate right away from the end of one of those grooves, but eventually that weakened section of bar will come back and bite you. And really, it's already a 45+ year old spring with who knows how many miles, so who knows how long it'll last.
              Toss 'em. Even in mint condition they're not worth that much.
            • jdsduster
              jdsduster Well-Known Member
              1,230
              210
              Aug 5, 2011
              indiana
              Local Time:
              12:05 PM
              wow,its good,its bad,its good ,its bad.use at your own risk.ive personally never had one break.i would buy a new one,they are not that much,that way you will know for sure its good
              • Thanks! Thanks! x 1
              • Agree Agree x 1
              • Daves69
                6,101
                4672
                Feb 20, 2011
                WestOfChi
                Local Time:
                11:05 AM
                They sound like a M-80 or Silver Salute going off under your car accompanied by fast drop of the affected front side of your car.
                Be careful handling the as the broken edges will be extremely sharp.
                • Agree Agree x 1
                • OL DODGE
                  OL DODGE Well-Known Member
                  224
                  109
                  Mar 25, 2012
                  Fairview Park,Ohio
                  Local Time:
                  12:05 PM
                  I wouldn't use it-IMO. A lot of excellent points against using that have been made, That's what makes this website so awesome-you get educated,opinions, and real life experiences. Wish it would've been around in the 80's when I was learning the hard way!
                  • Agree Agree x 3
                  • marksmopar1
                    marksmopar1 Well-Known Member
                    673
                    145
                    Feb 21, 2014
                    Winnipeg, Canada
                    Local Time:
                    11:05 AM
                    My Buddy's RoadRunner was just sitting in the driveway, he was in the house and heard huge bang! When he went out to look he found his RR sitting low on one side, the damn T-Bar broke as the car was sitting! He had just returned from a ride. So these things do go bang big time when they go....I would just get new, why take the chance...sell those ones you have to those guys that think the bar is ok..let them run them ;)
                    • Like Like x 2
                    • chryslerfat
                      chryslerfat Well-Known Member
                      14,440
                      15497
                      Aug 23, 2008
                      Monroe,Michigan
                      Local Time:
                      12:05 PM
                      Mom and dads Fury Sport was the same way. Sitting in the garage and heard a bang went out to see what it was and the car was down on the right side.
                      • Like Like x 1
                      • valiantwagonguy
                        valiantwagonguy Well-Known Member
                        1,095
                        792
                        Oct 20, 2005
                        Long Island
                        Local Time:
                        12:05 PM
                        That bar is garbage
                      • Rudy`s Ride
                        Rudy`s Ride Well-Known Member
                        265
                        131
                        Jun 13, 2014
                        Birch Island
                        Local Time:
                        11:05 AM
                        Those are great to use for horseshoe pit stakes.
                        • Like Like x 2
                        • Agree Agree x 1
                        • jos51700
                          6,058
                          2851
                          May 24, 2009
                          Bel-Ray
                          Local Time:
                          11:05 AM
                          My point exactly. It can be done, but it ain't worth it.
                        • 72bluNblu
                          11,911
                          6973
                          Nov 28, 2008
                          NorCal
                          Local Time:
                          9:05 AM
                          I think you missed my point. It can’t be done.
                          Removing enough material to remove the stress risers from the damage will create a section of bar with a different diameter. With the way a torsion bar carries load that section will operate at a different torsional rate then the rest of the bar. It might last longer than running it as is, but eventually it will break in that spot. You’re just trading a stress riser fracture for a fatigue fracture in the section of bar with a narrowed diameter.
                        • SGBARRACUDA
                          SGBARRACUDA ROY FABO Gold Member
                          21,995
                          10460
                          Dec 7, 2006
                          PLANT CITY FL.
                          Local Time:
                          12:05 PM
                          Owned Mopar my whole life, never broke one. And before I knew better would use a pipe wrench to grab the bar and knock them out with a hammer when rebuilding front ends. I would stick back in and run them. Never had a failure. Maybe I was lucky? Could it fail? Maybe. Those bars are tougher than some would have you believe. In normal use they are subjected to all kinds of road hazards and debris attacking them.
                          • Agree Agree x 1
                          • jos51700
                            6,058
                            2851
                            May 24, 2009
                            Bel-Ray
                            Local Time:
                            11:05 AM
                            It can be done. All one has to do is remove material along a significant portion of the bar. Let's face it; even the hex ends are larger than the bar diameter (well, the new bars not so much), and they don't break at the ends because the radius is large enough.
                            As I said....IF you can guarantee those three things...otherwise, not worth it.
                          • oi81b4uu812b4
                            oi81b4uu812b4 Well-Known Member
                            243
                            131
                            Mar 7, 2016
                            Michigan
                            Local Time:
                            11:05 AM
                            Old torsion bars make good pry bars!
                            So it does have a use!
                            • Like Like x 2
                            • Agree Agree x 1
                            • MRGTX
                              MRGTX Well-Known Member
                              1,967
                              770
                              Sep 24, 2007
                              CT, USA
                              Local Time:
                              11:05 AM
                              I follow your logic here and I think you're right. Some confusion may be coming from the instructions in shop manuals that suggest cleaning/polishing/painting scratches and nicks in the bars as the recommended procedure...but the important distinction here seems to be a matter of degrees. A scratch deep enough to alter the spring rate of the bar (and at the outer edge, it doesn't take much) is a "ticking time bar." :D
                              I get that torsion bars aren't exactly the cheapest component to replace but they're also not so expensive that anyone in the car hobby shouldn't be prepared to replace a set when necessary. Put these in the category of brake calipers, ball joints, etc... they'll typically last a long time but when they need to be replaced, it's non-negotiable.
                            • Dartnut
                              Dartnut Don't hate me because i'm beautiful
                              11,875
                              5012
                              Apr 19, 2007
                              Southern Alberta
                              Local Time:
                              10:05 AM
                              What's your life or someone else's worth?
                              You can buy new ones for pretty cheap...........
                              My vote is to cut it in half and use it for a pry bar etc. before someone decides it's ''good enough'' to use.
                              • Agree Agree x 1
                              • mikebee
                                mikebee now's the new later...
                                1,920
                                81
                                Feb 23, 2011
                                n.c.
                                Local Time:
                                12:05 PM
                                I've had one break with me sitting in the driver seat just got back from a hell ride and I'd still use that one if its a 340 bar.
                              • RustyRatRod
                                RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                                81,266
                                60781
                                Jun 7, 2010
                                Georgia
                                Local Time:
                                12:05 PM
                                I've run much worse......but didn't know it. Why take a chance when new bars just don't cost that much?
