How to cut throttle cable
Fuel and Air Systems
  1. BWDart
    BWDart FABO Gold Member FABO Gold Member
    1,264
    337
    May 25, 2005
    New Braunfels TX
    Local Time:
    7:41 PM
    I got a new cable how do you cut them without frayin? Dremel with cutoff wheel? I know side cutters don't work.
    Thanks
  2. Tad
    Tad FABO Gold Member FABO Gold Member
    466
    370
    Jun 19, 2018
    Not here
    Local Time:
    5:41 PM
    Go buy a pair of cable cutters for bicycle cables. They work amazing. Company that sells them is called park tool
    • Like Like x 1
    • Agree Agree x 1
    • Demonracer
      Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
      3,572
      1516
      Jan 31, 2010
      Cleveland, Texas
      Local Time:
      7:41 PM
      I dunked mine in plastic dip around where I needed to cut it, let dry overnight & cut it the next day.
    • BWDart
      1,264
      337
      May 25, 2005
      New Braunfels TX
      Local Time:
      7:41 PM
      Thanks I'll check them out
    • RedFish
      RedFish Well-Known Member
      24,290
      2880
      Sep 5, 2007
      Local Time:
      7:41 PM
      I haven't cut a throttle cable but lots of other larger cables. Wrap tight with electric tape. Cut with a cold chisel.
      • Like Like x 1
      • Oldmanmopar
        Oldmanmopar Going left turning right FABO Gold Member
        8,435
        4613
        Jan 8, 2009
        Danielsville Pa. 18038
        Local Time:
        8:41 PM
        If I may ask why are you cutting a throttle cable?
        • Agree Agree x 1
        • Tooljunkie
          Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
          14,933
          14089
          Jul 22, 2017
          Manitoba
          Local Time:
          7:41 PM
          Im guessing universal type.
        • Treblig
          Treblig Well-Known Member
          5,890
          3016
          Oct 5, 2013
          South Texas
          Local Time:
          7:41 PM
          Cuz it's too long?????/:rofl::poke:
        • Tooljunkie
          14,933
          14089
          Jul 22, 2017
          Manitoba
          Local Time:
          7:41 PM
          A short piece of heat shrink will dress it up after as well
        • BWDart
          1,264
          337
          May 25, 2005
          New Braunfels TX
          Local Time:
          7:41 PM
          Ya lokar universal
          And it is too long yuk yuk
        • krazykuda
          krazykuda Well-Known Member FABO Gold Member How-To Section Editor
          53,700
          18689
          Aug 20, 2007
          Orland Park, IL
          Local Time:
          7:41 PM
          That's what she said... :D
        • halfafish
          halfafish Damn those rabbits, and their holes! FABO Gold Member
          1,574
          1374
          Aug 14, 2016
          SW Washington
          Local Time:
          5:41 PM
          I give them a good soaking in crazy glue and let it dry, then cut it with a big set of dykes. The side-cutter kind, not the butch kind. :rolleyes:
          • Thanks! Thanks! x 1
          • Agree Agree x 1
          • inertia
            inertia Well-Known Member
            3,222
            531
            Feb 4, 2011
            Victoria B.C. Canada
            Local Time:
            5:41 PM
            Solder
            • Agree Agree x 1
            • Oldmanmopar
              8,435
              4613
              Jan 8, 2009
              Local Time:
              8:41 PM
              I never installed a loco kar cable. I have removed them after they ripped and install a factory cable for customers who got sick of the cable ripping when driven long distance. I went home and got parts for guys to drive back home from Carlisle. They showed up the following year and still had the same factory system I installed.
              There are different lengths that mopars have and many different brackets. You just have to get creative and understand the mechanics and geometry. Truck ,six ,SB and ,BB, a body 340,318, /6, and many others in different bodies. I never came across a carb and intake I couldn't use a factory cable and brackets on. Even this truck with a blower with dual quads I used a factory cable and throttle pressure. My Duster I believe was a 318 or /6 cable and a big block truck bracket I modified using a 318 one. I know the aftermarkets look amazing and they provide everything you need. But they are just not made to withstand High mileage abuse. Not only that most are not made in the U.S.A.. Make it yourself. "Made in U.S.A". I love salvage parts. F--K China. If not U.S.A. I'd sooner buy Mexican and Canadian
              • Like Like x 2
              • Bulldozer
                Bulldozer free ice cream sandwiches
                15,513
                2312
                Oct 16, 2011
                behind the wheel
                Local Time:
                7:41 PM
                I get a rise making the factory brackets/cables/kick down/ shifter linkage all work. I refuse to use aftermarket crap
                • Like Like x 1
                • 67Dart273
                  67Dart273 FABO Gold Member FABO Gold Member
                  43,554
                  11107
                  Oct 14, 2010
                  Idaho
                  Local Time:
                  5:41 PM
                  I've done this. You don't want to solder too "lengthy" as you don't want solder down into the "flex" area. Use an acid flux, figure out where you want it cut, and just tin the cable as you would a wire.
                • Oldmanmopar
                  8,435
                  4613
                  Jan 8, 2009
                  Local Time:
                  8:41 PM
                  I once went to a cruise. I guy pulled in opened his hood and took the breather off. I walked over and asked him if he needed help. He said "Nope take a look" He just wanted to show all the fancy anodized bracketry . It did look pretty cool. Made it look like big money invested. I told him he should just put a small coned air horn on it. Next time I saw him that was what he had. I actually liked the look and gave him the thumbs up.
                  Me? I cover my ugly home made shit up with a home made breather.
                  • Agree Agree x 1
                  • BWDart
                    1,264
                    337
                    May 25, 2005
                    New Braunfels TX
                    Local Time:
                    7:41 PM
                    My Dart is a 72 318/2bbl originally now a 360 4bbl which oem cable should I buy?
                  • Oldmanmopar
                    8,435
                    4613
                    Jan 8, 2009
                    Local Time:
                    8:41 PM
                    small block 4bbl's have the shortest cable. But your 318 cable will work. Y
                    If your intake is a lot higher like mine was you'll have to make a bracket . The cables all have the same pull distance it is the total length that is long and short. Remember there is a mopar bracket that is needed for all non factory carburetors, it bolts tho the carb. The throw on all mopars is the same so the cable just has to reach the bracket. You need a cable if it doesn't reach the clamp. You need to find the 4bbl bracket that bolts on with the intake. The 2bbl braket puts the cable clamp to far back from the carb. and to far to the right. Here is a 2bbl vs 4bbl.
                    Like I said no matter how short or long the total length is they all have the same throw pull distance. You are looking for the orange intake bracket Pictured below for a standard to medium intake. the blue set up is 2 bbl. Note how far the cable clamp is moved forward and stood up for 4 bbl. to move it out for the width of the carb.
                    • Like Like x 2
                    • inertia
                      3,222
                      531
                      Feb 4, 2011
                      Local Time:
                      5:41 PM
                      Tin it before you cut it ! !
                      • Like Like x 1
                      • BWDart
                        1,264
                        337
                        May 25, 2005
                        New Braunfels TX
                        Local Time:
                        7:41 PM
                        Thanks for the great pics
