BWDart
I got a new cable how do you cut them without frayin? Dremel with cutoff wheel? I know side cutters don't work.
Thanks
Thanks
Thanks I'll check them outGo buy a pair of cable cutters for bicycle cables. They work amazing. Company that sells them is called park tool
Im guessing universal type.If I may ask why are you cutting a throttle cable?
Cuz it's too long?????/If I may ask why are you cutting a throttle cable?
A short piece of heat shrink will dress it up after as wellIm guessing universal type.
Ya lokar universalIf I may ask why are you cutting a throttle cable?
Solder
My Dart is a 72 318/2bbl originally now a 360 4bbl which oem cable should I buy?I never installed a loco kar cable. I have removed them after they ripped and install a factory cable for customers who got sick of the cable ripping when driven long distance. I went home and got parts for guys to drive back home from Carlisle. They showed up the following year and still had the same factory system I installed.
There are different lengths that mopars have and many different brackets. You just have to get creative and understand the mechanics and geometry. Truck ,six ,SB and ,BB, a body 340,318, /6, and many others in different bodies. I never came across a carb and intake I couldn't use a factory cable and brackets on. Even this truck with a blower with dual quads I used a factory cable and throttle pressure. My Duster I believe was a 318 or /6 cable and a big block truck bracket I modified using a 318 one. I know the aftermarkets look amazing and they provide everything you need. But they are just not made to withstand High mileage abuse. Not only that most are not made in the U.S.A.. Make it yourself. "Made in U.S.A". I love salvage parts. F--K China. If not U.S.A. I'd sooner buy Mexican and Canadian
small block 4bbl's have the shortest cable. But your 318 cable will work. YMy Dart is a 72 318/2bbl originally now a 360 4bbl which oem cable should I buy?
I've done this. You don't want to solder too "lengthy" as you don't want solder down into the "flex" area. Use an acid flux, figure out where you want it cut, and just tin the cable as you would a wire.
Thanks for the great picssmall block 4bbl's have the shortest cable. But your 318 cable will work. Y
If your intake is a lot higher like mine was you'll have to make a bracket . The cables all have the same pull distance it is the total length that is long and short. Remember there is a mopar bracket that is needed for all non factory carburetors, it bolts tho the carb. The throw on all mopars is the same so the cable just has to reach the bracket. You need a cable if it doesn't reach the clamp. You need to find the 4bbl bracket that bolts on with the intake. The 2bbl braket puts the cable clamp to far back from the carb. and to far to the right. Here is a 2bbl vs 4bbl.
Like I said no matter how short or long the total length is they all have the same throw pull distance. You are looking for the orange intake bracket Pictured below for a standard to medium intake. the blue set up is 2 bbl. Note how far the cable clamp is moved forward and stood up for 4 bbl. to move it out for the width of the carb.
