Hello,
I have been driving my '66 Dart quite a bit over the last 10 days or so after doing a lot of work to it. I've posted my progress (and story) over in the early A section. I have had a few issues pop up and need a hand with them.
The battery, over the course of the last few days has been getting weaker and weaker. Today, it was dead after kicking the engine over only a couple times. I didnt dig too deep yet, but a quick visual inspection revealed a possible cause. I was wondering if anyone would know.
See this pic.
The two wires are in the middle connector, bottom right. Green and blue. Both wires are routed along the firewall, and then run along the valve cover to the front of the engine. The Blue wire is terminated at the Coil, while the green hangs loose. It has a ring connector attached to it as if it two goes to the coil. Im not sure what the reason would be though. Im wondering if this needs to go to the alternator?
Also, The wire that is burned, what circuit is this? This cannot be a good sign. There is not one single electrical load on this car that MaMopar didnt put there.
This picture shows the wire hanging loose(in the foreground).
See this pic.
