ignition and turn signal switches??
abodyjoe
Berlin,N.J. 08009
what brand ignition and turn signal switches are you guys using? they would go in a 70 dart column. want quality ones..
thanks in advance.
Not sure there is anymore, Joe, unless you can find "new old" When I got the 67 running (a few years ago) bought a brand new dimmer switch from NAPA. I don't drive much at night, I bet it didn't get 25 cycles on it, fell apart
There have been a lot of threads about crap signal switches from ebay/china. I know where to buy a premium quality signal switch for 1969 and earlier but 70 and later is not shown there. Maybe ask @slantsixdan . Good luck
I gave up on the china junk and carefully opened up the old switches and cleaned the old dried up grease and contacts. Also clean up the key tumbler and get that working smooth. I have found that shimming the slop between the "switch pin and u" with 1/4 washers keeps the switch working smoothly in all positions. Both my cars are column switches. A drop of loctite on the the switch mount screws also helps.
thanks in advance.
Abody get on to @slantsixdan he will put you in contact with a vendor which sell good quality switches , I received one my self and the quality is there and looks very close to oem. More expensive than the junk on eBay. same colour code wiring . Made in the US .
