Kendog 170
Let the boy go !
This motor has been for sale up in my neck of the woods.
mopar dodge 5.2L 318 magnum aluminium small block
If you are using LA heads with a roller cam then use a pre magnum 88-92 roller cam block.
Right on, nice area out that way. Thanks for posting all your tech info on here, its definitely a big help.Summertown, 401 exit 804.
J.Rob
Under headed.Nothing like my tunnel rammed 340 sound going from 5000 to 7000 rpm. Im not big on strokers either. Unless you have big bucks for good heads. Otherwise your under headed.
