JENSEN distributor
Road/Rage
KY
I have a 440 and a 360. Both have Jensen Distributers from the factory. Can they be swapped from one to the other?
The only distributors that fit 440s are made for 413/426 either wedge or hemi and 440, and the oddball old RB 383 which you are very unlikely to come across.
I've seen FIRST HAND a 383 distributor running in a 318. .....and for quite some time.
I've seen big block distributors in a small block, too (with an adapter collar doohickey that kept the intermediate shaft from pushing up)- but it was in a reverse rotation marine engine!
:D
How did it reach the drive gear? Did they change the center shaft? The B engines have the shortest of all the shafts.
Nope. @Bighead440 is familiar with it, too. Maybe he'll chime in. I know he remembers it. He did some work on the truck. 383 distributor running in a 318.
Should be in the Guiness Book of Records.....as the 8th wonder of the world.
