Looking for suggestions on Pistons for a 360 LA .060
Owen Diaz
Jamaica New York
Looking for some Suggestions on what I should go with plan on using stock crank/rods flat tappet cams/lifters and J heads
As far as in stock options go this is what I see available on summit
IC745.060 KB356.060 KB107.060
IC9978.060
KB362.060
Also want to add I plan on getting the rods shot peened
Any and all information is helpful
Not sure if the chamber size all I know is there J heads do have pictures of the numbers in the head
Would I have to call for them to make it for me or would I be able to order them right on summit?
I'm not sure. Make SURE you look at those CLOSE. I kinda posted those as a joke. They would probably get you 12:1 compression. LOL
Lol yea I think 12-1 compression would be too much
Well, you didn't say WHAT you were doin. LOL That said, I TOTALLY agree with post #4. I've used the Sealed Power ones before and got 10.2 real easy. They are nice pistons.
I’m trying to make a street/strip build had another 360 with eagle rods and KB flat top pistons I think that was .30over and one of the rod bolts broke on me so I decided to buy a block from someone who had stock rods and crank and I just need the pistons to finish the rotating assembly
I’ve used the KB-107’s and the SpeedPro c116hp. There heights are very close to each other. With a J head, gasket thickness dependent, you can zero deck the piston and get a 9.8-1 ratio with the chambers being 72cc. Coupled with a reasonably healthy cam and overlap, this is pump gas territory and capable of mid to low 12’s with very streetable cams and gear ratios.
One example would be a 292 Purple cam and 4.10’s on 28 inch tires will get you mid 12’s w/un-ported heads.
BTDT
BTDT
Just to make sure I’m right you’re talking about these correct?
