autoxcuda
- Joined
- Apr 6, 2007
- Messages
- 9,533
- Reaction score
- 5,071
Yes,
I pressed the pin out and left the shell in the lca and on the shaft.
I just took the other side off and the rubber is obviously much thinner
than the poly. It did kick back the lca shaft to about 1/2" once the strut
nut was removed. I would imagine the poly will not compress like that though.
Also, the steel spacer in the center of the poly bushings is about 1/2" shorter
than the overall of the bushings and that is not including the frame thickness.
Whats the best thing to do here? Should I just use rubber bushings or
cut down the poly until I get a good compression on them? I was trying
to eliminate my death trap, not make a new one!
With the LCA hanging down real low without the shock hooked up IIRC the pin doesn't want to go all the way in. Try picking up the LCA to about level and see if you can move it foward some. You probably will need to back of the adjuster some more. Then you have to tighten the strut to move it the rest of the way forward.
Look in the K-member strut hole to check if the ridge on the poly strut bushing is seated in the hole.
To tighten the LCA pin you probably will have to use some channel locks on that shoulder on the LCA pin to hold it while tightening the nut. This is because the poly bushing will allow the pin to spin whereas the rubber bushings are molded and fused to the shells.
