ok...I have something for you.
I know 09/11/01 was orchestrated AGAINST the American People by the Bush Administration.....
Here are my FIRM Standing points to support this:
There was NO TITANIUM Boeing 757 Aircraft Parts found at the scene of the Pentagon....
No Luggage.....
No Bodies........
I might agree with you on this if it wasn't for the scores of sites all over the web with plenty of photos of wreckage, luggage, aircraft tires, wheels, and landing gear struts inside and outside the Pentagon. Here are a few:
http://whatreallyhappened.com/WRHARTICLES/ppfinal.html
http://www.abovetopsecret.com/forum/thread79655/pg1
http://www.rense.com/general32/phot.htm
The only released video footage of the impact on the west wall of the Pentagon shows a Vapor Trail and then and Explosion.....Vapor Trail + Explosion = Missle
That CCTV system in the early video is not a standard video system. It takes a series of snapshots. This should have been obivous to you from the patrol car that cruises slowly by and is only caught in 2 frames. An aircraft travelling at several hundred miles an hour would obviously be capable of being missed between the frames. This became even more obvious when the second, more stable video was released after being used in the Moussaoui trial in 2006 which shows the plane entering the field of view just above the ground. I guess you also missed the photos of the highway light pole it knocked down and the damaged vehicles?
The FBI confiscated all 35 PLUS Security Surveillance Videos from Hotels and Buildings in the vicinity that show the West Wall of the Pentagon Clearly and could have silenced any nay sayers once and for all and still to this day have not released any of them.
The F.B.I. wanted any video that might have evidence of the event? OMG!!! Come on man. I guess you have not read the testimony of the scores of witnesses who saw the plane coming in and also saw aircraft debris raining down afterwards? Debris that was photographed.
The WTC 1 & 2 were designed to withstand the Impact of commercial airliners. WTC Engineers have said on record that they should not have collapsed.
And even more engineers have testified that they were not and could not be designed to withstand the intense heat that would result from a full load of burning fuel confined in a small internal area of the building. Heat more than intense enough to melt steel.
After cleaning up WTC Debris and they got to near ground level they found the Support Beams were Diagnoly Cut with Thermite Bands and found high concentration levels of Thermite there too.
Geez. They have one picture of a diagonal break in one beam just above ground level, not where the building collapse began and the claim of thermate, which is a combination of thermite and sulphur, not thermite, found there is a B.S. rumour. Haven't you ever seen a video of a building brought down by thermite? The explosions are OBVIOUS, not only visably, but by the massive sound and shock wave. Did you notice such an explosion in the videos of the towers coming down?
President Bush sat there in the Florida Classroom listening to a book about "Goats" already notified of WTC 1 being struck......then when his advisor comes in and tells him of WTC 2......he sits there for another 15 minutes...WTF?
What should he have done in a room full of civilians? Run out in a panic? His job is to wait for the information to come in and make decisions based on that information, not run right to the scene.
I am not going to continue with this crap, but if you believe that some Muslims out in some cave in Afghanistan could conjur up a plan of that magnitude and execute it flawlessly with no rehearsal, and that the Bush-Bin Laden family friendship has nothing to do with OWNING the American People,.......................I would tell you: YOU NEED TO WAKE UP.
My friend, you are the one that needs to wake up. Everything you posted here has been thoroughly debunked by numerous independent sources. Yes, a small group of very well educated and very well funded men could easily pull of such an operation. They were not mere "muslims in a cave". Also, the Bin Laden family has had tight relations with every U.S. administration for over 20 years.
