flathead31coupe
I was told to use a hv oil pump and swap the spring out with a stock spring is the way to go....but also told a stock oip pump will be just fine with the 7 qt pan... thoughts....
Turbos can operate at very high RPMs, depending on the vehicle, make and model. It is very important to keep the oil supply entering the turbo full and clean to ensure proper lubrication. If the oil supply drops too low or becomes contaminated with debris, it is highly likely that the turbo unit may become damaged.
