blue missile
Ok
Here are the pics from todays work of fabricating and installing a radiator/frame reinforcement.
Its made out of 2"x3"x1/8" tubing, and I did take some shots right after I cut the piece, but it helps to put the memory card back in the camera. So I had already started to bend it in place when the photos start.
I still have to put a gusset plate on each side, but I ran out of gas. I did box the front 1/3 of the rails (the easy part) So I colud get the support in.
The top of the support is exactly where the old sheet metal was so a standard radiator can be used. The bottom is still 1/2" above where the bottom of the frame is, so no ground clearance was lost.
Just a note to those without tube benders, get'er done anyway:-D
What do you guys think?
Andrew
Andrew
