Well then you have the wrong or bad oil pump drive. Get a new one.
But in his picture he is comparing it to what I assume is the original?if it had no bushing, the shaft would sink another 1/8 inch, that's all the bushing flange is worth. It would be obvious if the gear wasnt visible down in there. I bet you got a 383 distributor.
You may be right. I'm not sure what he's got going on.Yeah.. he has a china cheapo one thats right and an MSD 440 length...too long! Now Im confused if he actually has a oil pump drive in there! Its a big round flat faced circle with teeth and a slotted hole in the middle. touching the cam gear..is it down there? There is no way that would seat if the pump drive was in there, bushing or not.
Yes, BTW...thanks to all y’all chiming in. Motor was running fine since I picked up car but was losing power and acting logy lately. Then it wouldn’t fire at all, pretty much determined it was MSD box failing and then dying-thus the slowing and sluggish deal. My muscle car mechanic said they see this periodically. Anyway, I will check new distributor for shims, that would be awesome if I can take care of it and get this bizatch Dart back on the road! Hambony.I disagree. An 1/8 is a lot in some worlds. This could be one of them. The intermediate shaft could also have been a bit short. Everything adds up.
OP, S-K Speed on Long Island, New York?
