Need advice for diff for 65 Dart factory hi-po 273.
Stumpy
WA
The rear end is whining on my just bought 1965 Dart with the factory hi-po 10.5:1 273 4bbl 4-sp set up with a 7.25 rear end. The tires are 205/70 R14s.
I'd like a 8.75 but it will be $$$ and time. Maybe some day, but for now I'm thinking to just keep the stock diff. It lasted 50+ years and I won't be beating on the car and way cheaper. Am I just wrong about this. Did a quick search and A body 8.75 look to be as rare as hen's teeth and I really want to return this car back to as original as I can with some modern upgrades.
The question is what gears should I order for it? The car won't be raced, and I'd like to be able to drive on freeway without winding it up with nice mid-range acceleration for merging or passing.
What was the most usual gear ratio for these out of the factory?
Check to see if you have a sure grip, both wheels turn the same direction. Could just be axle bearings. Usual gear was 3.23 on HP cars.
3:23 is a good gear. Plenty of pep in my 66 my Hi-po car and almost 20 mpg/ hwy.
Put an 8 3/4 posi n it with about a 3:55 ratio and I think you can flip gears in that trans to make fourth into third and third into overdrive. It would be an awesome driver and it's a good investment.
If you can find an 8.25 diff from a 73 up A body it would be a good choice. More than adequate for a 273. It would most likely
be BBP from a V-8 car.
If the car already had these upgrades, the previous owner could have sold it for a lot lot more money. Probably $3k more. If he would have sold it at all..it would be a pretty great car; as it is, it's just a local cruiser ready to break down.
No you can't flip gears.
The closest I can find so far for a 7.25 is 3.55. If someone has a lead on where I can get a set of 3.23s please let me know.
I think you better look things over and count the turns. It sounds like you aren't sure what gear is in it. No reason to order a 3.55 if it has a 3.23 in there. If the rear end is good, working , and not noisy I would leave it alone until you can find something better. 7 1/4's can't take much abuse so don't bet on it. They have to be set up in the car and are a turd to do even for the experienced mechanics.
I don't get it. I'm running 8:25 with 3:21 gears. Pulled off my rpm air-gap and put performer intake on earlier this summer with AVS-2 650 edelbrock. Mild 318 250hp 904 tranny. 25" tires in back. Anyway, was getting between 12-13mpg maybe 13.5 on hwy. After switching intakes maybe picked up 1/2 mpg. We do alot of cruising and would love to improve mpg somehow. I keep thinking since changing intakes I could get by with a 500 eddy. Anyway, saw your post and thought "how does he do that?"
9.6/1 HP 273 with the stock open plenum intake and a 600 Edelbrock. It has a Isky E4 cam still running the solid lifters. I also run the original dual point distributor with 8 ° initial and 32° total. Stock exhaust manifolds with Accurate LTD Hi-po single exhaust. I get 18+ easy and have gotten 19 on a 2 hour drive @55 mph. Oh, original 4 speed. (non overdrive)
There are so many ways to lose fuel economy , it ain't funny.
Economy starts with a lightweight car, a small highly efficient engine, very low cruise rpm, and ends with major tuning session.
But if I had a 318, it would be knocking on 24mpgUSg, Cuz it wouldn't be stock.
It would have alloy heads, a solid-lifter fast rate of lift cam, and a Dcr pushing 9/1 The cylinder pressure would be pushing 190. It would have a 4bbl with triple booster primaries, headers, and a free-flowing exhaust with dual full-length large diameter primary pipes, and huge triplepass muffs.It would have a close-ratio 5-speed manual trans and cruise at say 65=1800 rpm. I would stick it in a lightweight chassis of no more than 3400 car and driver.... cuz I already have one lol.
I bet I can tune that hi-compression teener to do better than 24.I mean I have a 367, that in one iteration easily surpassed 24, so a 318 should be a breeze.
But yer not likely ever gonna get that out of a stock low-compression LA-smoggerteen with an A904, and I don't care what gears it runs, or how light a factory chassis you stuff it into. Well, maybe you can; but I sure couldn't,lol.
The point is this. if your 318 is only getting 13.5mpgs, IMO, there is either something you're not telling us, or your combo is in serious trouble.,
I agree with 66FS. Axle bearing are most common source of noise and vibration. Check those first.
