Matts440
I have the ritter block for my build, cast iron, 9.6 deck, 3.999 bore was 2700 shipped from Ohio where they are made and machined to my door in California. The shop here has done whitedarts aka Shilo machine work, he actually referred me to them QMP racing. With bore to spec, blue print to double check everything, roller cam bearings 50mm, bushed the cam lifter bores and opened them to .937 ran about $3k with diamond hone. Shilo also got a first gen block, I showed him mine among with another guy on moparts who got the aluminum, said mine looked way better then the earlier block, Kent Ritter even took suggestions and made changes to the molds to help make things better where they should be over where he had them. Only issue I had was i ordered 340 main size and they machined the oil pan rail on the rear cap to a 340, where the website from Hughes says it uses a 360 pan, so I bought a 360 pan, but talked to Kent, shipped the cap back to him and he machined it to a 360 for free, just has to pay shipping there which wasn't much.
