Hey guys, I thought I was being careful. What's the best way to fix this, so it's done when the time comes to put them back on? Headlight chrome on a '75 Valiant Brougham. Thanks!
First thing to do is clean them up real good, get out the magnifying glasses and see what I have. The epoxy glue sounds the easiest for me but, it will be awhile before the car is painted and ready for the chrome. Thanks guys for all the suggestions!Epoxy glue for metal, will hold just fine. ^^^^^ Like he mentioned above.
That will work. I would for sure use JB Weld. it costs a little more, but it might just be the best epoxy there is.First thing to do is clean them up real good, get out the magnifying glasses and see what I have. The epoxy glue sounds the easiest for me but, it will be awhile before the car is painted and ready for the chrome. Thanks guys for all the suggestions!
Woody
Momoparman, thanks for the advice. I will do that. I haven't been able to look yet, but I assume you can't buy new tabs? I'm curious though, any ideas on where to start looking?Sand the crap out of the mounting pad on the trim with 60-80 grit. Sand the back of the rusty tab with the same. Make sure the rust is gone on the surface you will apply the glue. Use Acetone or fingernail polish remover to clean. Epoxy will grab those scratches and never let go! The sooner you do them the longer they will have to cure.
