Newbie needs 273 spark plug help
Ciguatera
Active Member
Virginia
Hi,
I just joined FABO and posted a brief introduction in the Welcome Wagon forum. I'm very happy to be here and looking forward to learning from all the A body experts. I just bought a stock 1965 Barracuda Formula S with a 273 Commando and 904 automatic. This is my first technical question on the forum, and appropriately for a newbie, it's sort of a dumb question:
What spark plugs fit a stock '65 273 4bbl? It has the original 10.5:1 iron heads. I failed to find any plug specs in the service manual, though I'm sure it's there somewhere in the 700+ pages. When I enter the year make and model on car parts websites, I get all kinds of different plugs. Some are 3/8" reach (length of the threaded part of the plug), some 3/4". Heat ranges are all over the place. Some are even non-resistor.
I'm particularly concerned with the reach length. I have domed pistons and I'd like to avoid turning the Commando into scrap metal on start up!
Thanks in advance!
You will find that the parts counter books are pretty stupid regarding the 273-4bbl. So don't be afraid to ask more questions.
Just wait until you try to replace the points...
I have restored a lot of small block dual point distributors, about 3 years ago standard decided that small block and big block use the same points, I have sent them emails and talked to the sales people and nobody understands.
I have the part numbers so I just order the number and if the warehouse has them I get them, or maybe another store might have them, I know they are going extinct and I'm not sure we can fix it.
Thanks for all the plug replies. Good to know about the points too. I think I'm going to keep the mechanical ignition. Going by Toolmanmike's points thread, I guess I should get NAPA/Echlin CS721A points and several condensers in case I get a bad one. So much to think about!
I have pertonix igniter 2. Installed by techs at their San Dimas Corp office. Original prestolite distributor
If you have the kit number please post it and I can add it to my thread for future reference. Thanks.
Rockauto will list most plugs which fit. Platinum or iridium should last longer, but I don't know if they work poorer with points ignition.
You can even get up-dollar points from Accel, but don't know if actually better. Main thing is to get a dwell meter so you can set the gap precisely. Feeler gages are just to get it close. Dual-point distributors are trickier to adjust (I never had one). Even then, points will never give as strong a spark as electronic ignition w/ an e-core coil. To best protect your engine, the Pertronix Ignitor III has a rev limiter, which might be especially important on your engine which can really spin up.
