DusterDeano
Hello everyone, I know there a probably a few threads on this so please forgive me if this is a repost with a similar issue...
I know literally nothing about wiring and this is my first Mopar so I'm still learning the ropes, I will try describe best I can what the issue is. I also live in the UK so parts aren't readily available to me to buy and test within a few days, especially with current shipping costs!!!
Hopefully nothing needs replacing and this is a simple fix...I can but hope lol
Basically everything on the car worked fine. I can't remember exactly when they decided to stop working but a few things I have done on the car recently are:
The only ones that do not work are the turn signals, the green arrow on the dash doesn't appear to be working either. When I turn the switch left or right there is nothing. No noise coming from the flasher unit, nothing.
When I hold the brake down, my brake lights work but when I select left on the turn signal the left brake light goes out and the right brake light stays on, when I put it back to the middle both brake lights appear, the same happens when I select right side...the right brake light goes out but the left stays on.
Few things I have tried...
Sorry, car is a 72 Duster.
- Install a retro sound radio
- Installed a tach (had to drop the steering column & pull the dash out a little to neatly feed the tach wires behind it).
- Accidently pulled the plug seen in picture below whilst messing with my steering column and didn't know where it had come from (It was hanging in the engine bay near the brake booster, I later started the engine but heard a fuse blow and then found my tail lights had gone out. Replaced the fuse and eventually saw near the bottom of the car where all the brake lines were a fitting for it to go on. Fitted it back on and brake lights now work again.
- I tested the flasher unit on my dad's Lincoln, it works fine. So the unit is working.
- I checked all fuses, everything is working. Used a test light on them and all is good.
- I pulled the flasher unit and used the test light on the wires - there was no power going to the flasher unit.
- I pulled the steering wheel off and ran a live wire from the battery to the signal switch, this worked. It powered up the green arrows and the left or right lights came on at the rear. They didn't however flash, they were just constantly on. There was also no noise coming from the flasher unit.
- I used a test light again on the wires connecting to the flasher unit whilst running a live from the battery to the switch and yes this was indeed live now.
