Gerald, thnx! you nailed this. Sure enough there it is behind kick-panel as you pointed out it should be on '68. So....all is wired OK up to the the weird stuff at the horns.... Someone in distant past that replaced the front clip with a '67 saw an unused relay in the engine bay by the horns and felt need to take one of the two hot horn wires and attach one to the the relay and the other to the single horn on the '67 front end - then attach some unused black ground to the other terminal on the relay. All for nothing actually. Betting the old '68 clip had two horns and the green/red with two female connectors fed each of them. So when I mount my two new horns where they should go on a '68, all I need to do is use the two existing hot leads....and ditch the relay near the horns which BTW is actually using one of the horn bracket holes anyway. Thanks for your patience guys. Very happy not to be pulling steering wheel , etc. etc..
