oil dipstick
dusterboyy440
Sooo i went aheah got my cage finally done and jus put my 440 in my 70 duster..the k frame is a 73 and up though...well it sees like there is absolutely no way for the oild dipstick to fit behind the motor mount!!! wat do i do?? :angry7:
Did you modify the k-member? What mounts are you using?
I can tell you that the dipstick fits with a 73-76 V8 k-member modified to Direct Connection specs with 74-78 big block mounts, BUT it's a tight fit and may require a little bending.
