Open or with holes?
Denvermike
Denver
I've got a 66 Barracuda with a 360. Mild Comp cam, .040 over, stock pistons and heads. EDY preformer and 1405 600 CFM. I want to try a carb spacer. Should I get the open center or the 4 hole style? Car will be weekend fun driver.
Thanks,
Mike
You might feel old when your wife who needs a knee replacement can walk faster than you can.
4 hole. If you can borrow one, even better. Ask around. Tyey used to be cheap to purchase.
if you live near a autozone you can buy 1 that you swap out the center form open to four hole that way you can have and test both..they cost about 30.00 or less....but for your build i think the four hole is the way to go...be nice to try both back to back at the track..i never got to try from 1 to the other at the track to lazy i guess and car was running ok lol..wish i had..mike:violent1:
