mopowers
Do you folks know of a good over the counter ZDDP oil additive that is likely to be on the shelf at a local auto parts store?
Valveoline ZR1 is high zinc.
Doesn't the Lucas ZDDP tell you to use the whole bottle with 5 quarts?If your dad chooses the Lucas additive, it looks like 1/4 of a bottle (4 oz) is quite adequate to raise the ZDDP levels to the 1200-1400 ppm range or thereabouts, which is the ZDDP concentration range where most motor oils used be. Too much ZDDP has been documented to cause its own set of issues; the whole Lucas bottle will raise it to around 5000 ppm per the Lucas documents, and that is way too high.
Yes it does. BUT, their data sheet says it will raise the ZDDP levels up to around 5000-5200 PPM. That is 3-4 times the ZDDP levels in the oils prior to the ZDDP reductions.Doesn't the Lucas ZDDP tell you to use the whole bottle with 5 quarts?
Good info there sir!!!! Thanks!Yes it does. BUT, their data sheet says it will raise the ZDDP levels up to around 5000-5200 PPM. That is 3-4 times the ZDDP levels in the oils prior to the ZDDP reductions.
- Typical old levels were in the 1500 PPM range. That got reduced to 1100-1300 PPM range in the 90's and issues were not showing up with cams.
- New levels on the oil weights 30W and lower are now in the 600-800 PPM range, starting around 2005 or 2006 and THAT is when the issues cropped up.
- If you add the whole Lucas bottle to a newer oil and raise the ZDDP level to 5000-5200 PPM, then you have raised ZDDP levels by 7 to 1, but you only need to go up by 2 to 1. You have increased ZDDP levels by around 4000-4400 PPM.
- If you add 1/4 of a bottle, then you have added about 1000 PPM to the ZDDP levels, putting the final level up in the 1600-1800 PPM range, which is higher than the old old standard.
- Excess ZDDP has shown issues in studies going back as far as the 1970's. Here is just one link that can be found describing issues; others can be found by Googling 'excess ZDDP additive problems'.
How much Zinc and Phosphorus is too much,? | Passenger Car Motor Oil (PCMO) - Gasoline Cars/Pickups/Vans/SUVs | Bob Is The Oil Guy
Great post, sir. I didn't even bother to read the link, you said it well enough yourselfYes it does. BUT, their data sheet says it will raise the ZDDP levels up to around 5000-5200 PPM. That is 3-4 times the ZDDP levels in the oils prior to the ZDDP reductions.
